Author Topic: Multiple i2c devices that have their own pull ups.  (Read 2916 times)
Offline Dan MoosTopic starter
« on: October 10, 2016, 03:26:48 am »
Say I want to use a bunch (6 or more) LCDs with those i2c backpacks that are pretty common. The back packs have their own pull ups. I imagine this puts a limit on how many of these devices I can have on one bus before the parallel resistance of all the pull ups becomes too small.  I haven't actually looked to see what value pull ups are on the things.
For my idea to work, do I need to ditch the backpacks, and just get the individual expander chips?
Offline Mr.B
Re: Multiple i2c devices that have their own pull ups.
« Reply #1 on: October 10, 2016, 03:29:30 am »
Perhaps desolder the pullups on all and add the pullups at your MCU.
Typical value is 4K7 but it can vary a bit.
Edit: Forgot to say... 6 backpacks? Do they support 6 different I2C addresses...?
« Last Edit: October 10, 2016, 03:31:10 am by Mr.B »
« Reply #2 on: October 10, 2016, 03:39:19 am »
The pins for setting addresses are brought out  on pads. You don't get the full range of addresses that are possible though. I think it's more than six, but I can't remember how many address pins are available. It's definitely a possible limiting factor on my plan.
EDIT: three address pins. My math says five combinations. So much for six screens!
« Last Edit: October 10, 2016, 03:43:20 am by Dan Moos »
Offline Mr.B
« Reply #3 on: October 10, 2016, 03:48:46 am »
3 bit address.
My math says 8 addresses.
Thats not to say the device supports all 8.
URL for spec sheet?
Photo?
Offline Mr.B
« Reply #4 on: October 10, 2016, 03:52:11 am »
Depending upon the device it could be a lot more than 8 - although unlikely for an LCD.
Some devices these days are using a sort of tri-state address pin combination.
e.g. one pin supports three addresses - High, Low and Floating.
« Reply #5 on: October 10, 2016, 05:20:37 am »
Yer right, three makes eight.
Pretty sure no tri state. The chip is a pcf8574. The board brings the address pins out on pads. There are also three corresponding pads that are go to either pull ups, or pull downs (can't remember as I sit away from the lab) so you can conveniently bridge different combos to get the address you want. I would assume having low/high/tri state would require a more elaborate setup.
Offline Mr.B
« Reply #6 on: October 10, 2016, 06:15:37 am »
One last piece of advice...
Six devices on an I2C bus can be problematic.
Keep your bus lengths as short as possible.
« Last Edit: October 10, 2016, 06:17:13 am by Mr.B »
Offline Neilm
« Reply #7 on: October 10, 2016, 06:48:23 pm »
Just make sure that your rise times are in spec for the chips - this might mean putting the pull up resistors somewhere you didn't didn't expect to. I have had five on a bus that was about 1m long. Fortunately, it went over several boards, so the one in the middle ended up with the pull up resistors.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
