I have two 4-digit common cathode 7-segment displays connected to an old Microchip PIC. Since I couldn't measure LED current with a multimeter because of the multiplex speed, I hooked up the scope only to be surprised by these voltage spikes. Is this typical for switching LEDs so fast? Is there any concern?
1st image: between the 220 ohm resistor and the LED segment
2nd image: same, but zoomed in
3rd image: between the PIC pin and the 220 ohm resistor
4th image: same, but zoomed in
