Author Topic: Need Help Atmega8 timer / Start-Stop on event  (Read 1774 times)
Offline mzdenkovTopic starter
  • Country: hr
« on: July 21, 2016, 07:48:12 pm »
Greetings.
I need help in:
Case:
Micro: Atmega 8
Timer event source: TDC1011
I need to start and timer on Event.
Event is change of state on External Pin.
So:
>---START--- [----------------]
from TDC      [  OR  GATE    ]------------AVR PINx------>
>---STOP-----[----------------]
<--TRIGGER-------------------------------AVR PINx---------
<--RETART--------------------------------AVR PINx----------
<--ENABLE--------------------------------AVR PINx---------
Im using TDC1011 to measure water level in glass.
TDC sends START bit at the begging of measure(here we start the timer) [it sends the ultrasonic signal], when TDC recieves the ultrasonic signal it sends STOP bit(here we stop the timer).
As im new in Timer capture mode, i need help (this is for my collage diploma project).
Best Regards.
Thanks.
« Last Edit: July 21, 2016, 08:53:58 pm by mzdenkov »
To Solder or not to solder, that is the question!
Offline dannyf
Re: Need Help Atmega8 timer / Start-Stop on event
« Reply #1 on: July 21, 2016, 11:00:17 pm »
Have you read the data sheet? There are countless ways of doing it.
  • Country: hr
« Reply #2 on: July 22, 2016, 05:57:10 am »
I did. I understand basic operations with timers, but there is a problem because i mix things between TI(collage lessons) and AVR.
I've read all in Datasheet, but that is not clear enough for me.
