Author Topic: need help for a circuit plan and a pcbdesign  (Read 1285 times)
Offline spiderboyTopic starter
« on: October 24, 2024, 11:21:49 am »
Hi everyone, i have two topics in which i am stuck:
dodow is a gadget that helps insomniacs by a blue led, that projects a breath simulating cone at the ceiling. i would like to build this gadget with a atiny85 microcontroller but i am stuck. could somebody design me a circuit plan for the following parts?:
- atiny 85 (6pins)
- led (dont know which one, it has to be able to do a small and bigger getting cone)
- 220 ohm resistance
- ttp223 touchpad
-ams1117 (3.3V) voltage regulator
- lithiumion battery 3.7v (500-1000mah)
- charge controller (tp4056)
-usbc socket (whatever you want suggest one pls)
I think those are all the parts needed...?
Second i would like to design the platine with kicad so i can easily print it.
Could somebody pls design me a circuit plan and the pcb design in kicad?
Thanks for help and im sry for bothering...
spiderboy
Offline ppTRN
Re: need help for a circuit plan and a pcbdesign
« Reply #1 on: October 24, 2024, 01:09:25 pm »
I would rather focus on how you are planning to produce the cone at the celing. I think you will need to mechanically block the light from the led in order to make it smaller and then bigger again. Using just a microcontroller you will only be able to control its luminosity
The following users thanked this post: spiderboy
