Author Topic: Omit Analog supply caps on MSP430?  (Read 2051 times)
Offline DTJTopic starter
« on: January 09, 2018, 05:04:46 am »
A silly question................
I've got a design using an MSP430F5359.
I'm not using the analog inputs at all.
I'm tight on space & cost - can I safely omit the filtering caps on the AVCC pin?
Should I still need to connect the 3V supply to the analog AVCC pin (I suspect yes..)
Cheers.
Offline ogden
  • Country: lv
Re: Omit Analog supply caps on MSP430?
« Reply #1 on: January 09, 2018, 06:35:11 am »
You can omit AVCC caps if you rely on DVCC caps. Just connect AVCC and DVCC together. Whatta product you have if you cannot afford extra 0.001$ for few SMD capacitors? :D
You must supply AVCC even if you (seemingly) don't use analog parts of uC. Excerpt from datasheet: "A maximum difference of 0.3 V between AVCC and DVCC can be
tolerated during power up and operation"
« Reply #2 on: January 09, 2018, 11:37:26 am »
Hahaha, cost is not an issue - space is a premium!
Thank you for your assistance. I'll hook the AVCC + DVCC together and let them share some caps.   :-+
