Author Topic: Orange Pi Zero  (Read 2421 times)
Offline CharlesSpongTopic starter
Orange Pi Zero
« on: February 14, 2017, 03:06:03 pm »
I am struggling to get the orange pi zero to work, i have tried two images so far debian jessie and ubuntu xenial both from the armbian website. Currently i am using jessie and all i can get is a blinking light on the left hand side of the ethernet port.
--Update--
Needed to use more stable power supply
« Last Edit: February 14, 2017, 03:31:48 pm by CharlesSpong »
Offline bingo600
Re: Orange Pi Zero
« Reply #1 on: February 15, 2017, 06:33:37 pm »
Have 2 on the way.
Sems like armbian would work ok.
They say you need a "stiff" 5V/2A PSU , and that WiFi is never going to work on the Zero (unstable & low throughput)
They also say @armbian, that the Orange's original OS'es overheat the CPU , due to crazy CPU poweregister settings.
/Bingo
Offline martinayotte
Re: Orange Pi Zero
« Reply #2 on: February 15, 2017, 10:57:20 pm »
Yes, Armbian is working fine on OPiZero, it can even boot from USB drive or dongle after flashing U-Boot into the SPI-NOR.
Offline HSPalm
  • Country: no
Re: Orange Pi Zero
« Reply #3 on: February 16, 2017, 09:06:19 am »
The Orange Pi Zero tricked me (or I tricked it), when I used both CR and LF when interfacing it during initial setup with the debug UART port. Linux doesn't like CR, or doesn't interpret it as I hoped.
