Author Topic: Original ST-Link V2 firmware  (Read 13995 times)
Offline AmperTopic starter
« on: February 01, 2022, 10:55:12 am »
Hi!
I just found an original stlink V2 in the dumpster, the stm32f103 is fried, most likely the thing got zapped by powerelectronics attached to the prog header.
Is there a compatible firmware out there?
Im especially interested in the ability to program stm8 wich i dont know the knock offs to be able to do.
ST offers fw updates but can i also just download a .bin?
Hopefully someone knows a path to revive that thing.
Online DavidAlfa
Re: Original ST-Link V2 firmware
« Reply #1 on: February 01, 2022, 11:56:58 am »
https://www.eevblog.com/forum/microcontrollers/dumping-stlinkv2-from-usb/msg3963365/#msg3963365
Edit: I made this last year as an emergency fix.
https://www.eevblog.com/forum/reviews/stm32-oled-digital-soldering-station-for-t12-handle/msg3350424/#msg3350424
ST-Link 4.3.0 worked well, newer versions didn't, since ST removed older versions, I uploaded it here
« Last Edit: February 01, 2022, 11:48:32 pm by DavidAlfa »
The following users thanked this post: Amper
« Reply #2 on: February 01, 2022, 01:10:21 pm »
Oh wow, i guess every topic has been talked about before :D
Thanks!
Offline GromBeestje
« Reply #3 on: February 01, 2022, 08:16:05 pm »
Find the ST Link Bootloader here https://github.com/Krakenw/Stlink-Bootloaders
Mind to use the 2.0 for STM32F103C8T6  and the 2.1 for STM32F103CBT6
Then find an older updater, as newer ones block a blank device. V30-ish should be ok I think.
Some old versions could be found here http://nic.vajn.icu/PDF/STMicro/STLink/
When that is flashed, you should be able to update to the latest version without problems.
« Reply #4 on: February 02, 2022, 08:23:35 am »
It worked, ST-Link is working again :)
Thanks!
