Author Topic: PIC Programmer using Arduino  (Read 4576 times)
Offline epyTopic starter
« on: November 07, 2018, 02:18:08 am »
This is Demo to guide how to build PIC Programmer using Arduino Board. We can use any Arduino board to program PIC Controller. This programmer works only on PIC which has Low Voltage Programming.
I am using PIC16F1847 pic which has Low Voltage Programming.
This project requires only arduino board and PIC which is to be program.
https://youtu.be/kpQ2t9pA1HQ
Re: PIC Programmer using Arduino
« Reply #1 on: November 07, 2018, 04:49:24 am »
Required Components:
Arduino Board With USB to Serial
USB to Serial (if USB to serial is not present on Board)
PIC Controller like PIC16F1847
Breadboard
Jumpers
LED
Resistor - 220 ohm
Here is Schematic for the Project
https://github.com/embhobbb/a-p-prog/blob/master/rough%20Schematic.png
Offline @rt
« Reply #2 on: November 08, 2018, 06:57:03 am »
At last! A proper use for an Arduino :D :D :D
« Reply #3 on: November 10, 2018, 06:46:46 am »
yeah ...  ;D
But Arduino is involved in almost all things some how. and even to develop the project on other architecture family arduino is required just like above.
Online jaromir
  • Country: sk
« Reply #4 on: November 16, 2018, 02:09:27 am »
Hello, author of the programming software here; I'm glad you found it useful. Should you verify it's functionality on other devices, let me know and I'll update the support table, or do pull request.
The following users thanked this post: cdev, bitseeker
Offline bitseeker
« Reply #5 on: November 16, 2018, 05:06:22 am »
Neat. Thanks for the heads up.
« Reply #6 on: November 16, 2018, 03:03:42 pm »
Hey Thanks for you study and research. I am happy to talk with you.
defenitely i will test for the PIC's which will be available for me and report to you..
