I hope someone can help with what I thought was a simple task but for the life of me I can't see it.
I am using a 12LF1572 to generate gate drive signals for a simple low frequency inverter. The signals are at 100Hz with a variable duty cycle 30-50%. So I'm using 2 PWM sources, I can set up the period and duty cycle correctly but I can't see how to get PWM2 to be lag by around half the period after PWM1 to give me a pair of non-overlapping pulses.
I thought that varying PWM2PH would allow me to shift the second PWM's phase relative to PWM1 but no, that would be too easy... how is it done?
Code so far below (ignoring config bits and trivial main() that calls init)pwm(duty_cycle) and then sits in a loop)
#define _XTAL_FREQ 16000000 // Oscillator frequency.
#define PERIOD 2500 // PWM period. With divide by 64 prescaler on
// HFINTOSC, PWM period is 2500 cycles of 16MHz/64
// i.e. freq = (16E6 / 64 / 2500) = 100Hz
// Initialise the PWM to a specific duty cycle and period
void
init_pwm( int duty_cycle) {
// Output PWM1 to pin 2 using RA5, PWM2 to pin 3 using RA4
APFCONbits.P1SEL = 1;
APFCONbits.P2SEL = 1;
// Set PWM pin RA5 and RA4 to be output
TRISAbits.TRISA5 = 0;
TRISAbits.TRISA4 = 0;
// Set PWM input to HFINTOSC clock, prescaler = div-by-64
PWM1CLKCON = 0b01100001;
PWM2CLKCON = 0b01100001;
// PWM control set to standard mode
PWM1CON = 0b11000000;
PWM2CON = 0b11000000;
// Phase
PWM1PH = 0;
PWM2PH = 0;
// Duty cycle in %
PWM1DC = duty_cycle * (PERIOD/100);
PWM2DC = duty_cycle * (PERIOD/100);
// Period
PWM1PR = PERIOD;
PWM2PR = PERIOD;
// Start the PWM's
PWM1LD = 1;
PWM2LD = 1;
