Author Topic: PIC12F675 C code doesnt work  (Read 3461 times)
Offline ocsetTopic starter
« on: May 24, 2018, 12:02:42 pm »
Hello
Do you know why this  C code for PIC12F675 doesn’t work?
Its using XC8 C
All it does is  make GP0 = 0  if the ADC reads the ‘busvoltage’ variable as being greater than 0x19. If the ‘busvoltage’ variable is less than 0x19 then it should make GP0 = 1;
However, it does not work.
I think its the ADC function doADC();  ...but i am not sure.
When i don’t   call the doADC function i have got it   able to oscillate the GP0 output. (but i don’t want the code to do that, we want the code to read ADC and act accordingly.)
//Main for the crammed long PCB
//Each Buckboost has a PIC12F675 to control it.
// PIC12F675 Configuration Bit Settings
// 'C' source line config statements
// CONFIG
#pragma config FOSC = INTRCIO   // Oscillator Selection bits (INTOSC oscillator: I/O function on GP4/OSC2/CLKOUT pin, I/O function on GP5/OSC1/CLKIN)
#pragma config WDTE = OFF       // Watchdog Timer Enable bit (WDT disabled)
#pragma config PWRTE = OFF      // Power-Up Timer Enable bit (PWRT disabled)
#pragma config MCLRE = OFF      // GP3/MCLR pin function select (GP3/MCLR pin function is digital I/O, MCLR internally tied to VDD)
#pragma config BOREN = OFF      // Brown-out Detect Enable bit (BOD disabled)
#pragma config CP = OFF         // Code Protection bit (Program Memory code protection is disabled)
#pragma config CPD = OFF        // Data Code Protection bit (Data memory code protection is disabled)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#include <stdint.h>
#include <pic12f675.h>
#define  _XTAL_FREQ 4000000
//#define  driversOff   GP0 = 1
//#define  driversOn    GP0 = 0
//#define  udhigh       GP2 = 1
//#define  udlow        GP2 = 0
//#define  cshigh       GP5 = 1
//#define  cslow        GP5 = 0
        uint8_t   count;
        uint8_t   count1;
        uint8_t   count2;
        uint8_t   busvoltage;
void zeropot(void);
void decrement(void);
void increment(void);
void doADC(void);
void up5steps (void);
void up35steps (void);
void up64steps (void);
        void up5steps (void) {
        for (count=5; count=0; count--) {
        __delay_us(100);
        GP2 = 0;    //UD = low
        __delay_us(100);
        GP2 = 1;    //UD = high
        __delay_us(100);
        return;
        void up35steps (void) {
        for (count=35; count=0; count--) {
        __delay_us(100);
        GP2 = 0;    //UD = low
        __delay_us(100);
        __delay_us(100);
        return;
        void up64steps (void) {
        for (count=64; count=0; count--) {
        __delay_us(100);
        GP2 = 0;    //UD = low
        __delay_us(100);
        __delay_us(100);
        return;
        void doADC(void) {
        //Initiate ADRESH, ADRESL
        busvoltage = 0x00;
        ADRESL = 0x00;
        __delay_us(100);
        ADON = 1;   //Turn on ADC module
        __delay_ms(1);
        GO_DONE = 1;    //start conversion
        while (GO_DONE) {;}     //Wait for conversion to finish
        __delay_us(100);
        busvoltage = ADRESL;
        ADON = 0;   //Turn off ADC module
        __delay_us(100);
        return;
        void increment(void) {    //GET DIGIPOT READY FOR INCREMENT
        __delay_us(100);
        GP5 = 1;    //CS HIGH
        __delay_us(100);
        GP2 = 0;    //UD low
        __delay_us(100);
        GP2 = 1;    //UD high
        __delay_us(100);
        GP5 = 0;    //CS LOW  ....NOW inCREMENT
        __delay_us(100);
        return;
        void decrement(void) {    //GET DIGIPOT READY FOR DECREMENT
        __delay_us(100);
        GP5 = 1;    //CS HIGH
        __delay_us(100);
        GP2 = 1;    //UD high
        __delay_us(100);
        GP2 = 0;    //UD low
        __delay_us(100);
        GP5 = 0;    //CS LOW  ....NOW DECREMENT
        __delay_us(100);
        return;
        void zeropot(void) {  //get wiper to bottom of resistor ladder, ie GND
        //ZERO THE DIGI POT
        __delay_us(100);
        GP5 = 1;    //CS HIGH
        __delay_us(100);
        GP2 = 1;    //UD HIGH
        __delay_us(100);
        GP2 = 0;    //UD LOW
        __delay_us(100);
        __delay_us(100);
        //Now decrement 64 times
        for (count = 65; count = 0; count--) {
            __delay_us(100);
            GP2 = 1;
            __delay_us(100);
            GP2 = 0;
            __delay_us(100);
        }                       //Now wiper is at the bottom.
        return;
void main(void) {
    //Setup ports
    //GP0 = OP  SHUTDOWN; High is shutdown
    //GP1 = OP  UNUSED OUTPUT
    //GP2 = OP  U/D MCP4013
    //GP3     = IP  MCLR
    //GP4/AN3 = IP  ADC input from input rail
    //GP5 = OP  CS MCP4013
    //To increment CS LOW, AFTER UD high
    //To decrement CS lOW AFTER UD LOW
    //HW SETUP
        GP0 = 1;    //SHUTDOWN
        GP1 = 0;    //UNUSED
        GP2 = 0;   //UD LOW
        //GP3 = INPUT
        //GP4 = ADC INPUT
        GP5 = 1;  //CS HIGH
        TRISIO = 0x18;   //ADC IN
        INTCON = 0x00;
        OPTION_REG = 0xD7;
        CMCON  = 0x07;
        ADCON0 = 0x0C;  //0000-1100 ADCoff_noconv; ch AN3; VREF=VDD;ADON is OFF//L just
        ANSEL  = 0x68;   //fosc/64, AN3,
        //5 second delay
        for (count=1;count<=10;count++)   {
        __delay_ms(1);
        GP0 = 1;    //Shutdown the led drivers
        zeropot();
        increment();
        up64steps();
        GP0 = 0;    //Turn on LEDs
        doADC();
        if (busvoltage >= 0x19) {GP0 = 1;}
        while(1) {;}
     /*   while(1) {
        GP0 = 1;    //driversOff;
        __delay_ms(100);                   }
        GP0 = 0;    //driversOn;
        __delay_ms(100);                   }
        return;
Offline StillTrying
  • Country: Broken Britain
Re: PIC12F675 C code doesnt work
« Reply #1 on: May 24, 2018, 12:49:00 pm »
Fosc/64 is 4 times too slow ?
The following users thanked this post: ocset
Online MarkF
« Reply #2 on: May 24, 2018, 01:25:38 pm »
Define "Does not work".
Does the LED stay ON or go OFF?
What voltage are you checking for?  (i.e.  What is 0x19?)
Online Buriedcode
« Reply #3 on: May 24, 2018, 01:46:55 pm »
You've set the result as left justified in ADCON0, and you're only checking ADRESL for > 0x19.
This effectively means the lower 6 bits of ADRESL are always 0.  And that the two MSB's are the two LSBs of the ADC result.  So... any ADC result > 0x00 will be seen as greater than 0x19, because an ADC result of 0x0001 would read b'01000000 in ADRESL, which is clearly greater than 00011001.
What you do depends on what percentage of VDD your threshold is set at.  Is the 0x19 (25 decimal) 25/1024 = 2.44% of VDD?  Or are you assuming you're reading the upper 8 bits of the ADC result? (0x19 is the first 8 bits of the ADC results (100/1024 = 9.77%of VDD)
If you're just reading the lower 8 bits of the result then change ADCON0 to 0x1C for right justified.  Otherwise read ADRESH for busvoltage.
« Last Edit: May 24, 2018, 01:53:35 pm by Buriedcode »
Offline SiliconWizard
« Reply #4 on: May 24, 2018, 02:29:16 pm »
You don't like function parameters, or functions that return a value, do you?  :popcorn:
(Oh, and a return statement at the end of a C function returning void is completely useless.)
And yes, there additionally seems to be a problem with the ADC sample format you are using as Buriedcode said.
But just looking at this piece of code makes me sad. I'm going to need a shot of whiskey.
« Reply #5 on: May 24, 2018, 06:57:11 pm »
Thankyou very much, i was taking "ADRESL" as meaning "ADRESS LEFT" instead of "ADDRESS LOW".
Your help is much appreciated.
Offline Howardlong
« Reply #6 on: May 25, 2018, 06:25:14 pm »
I think it’s supposed to be a short form for ADc RESult Low rather than ADdRESs Low.
Offline hexreader
« Reply #7 on: May 25, 2018, 07:12:56 pm »
This looks completely wrong to me. Try...
for (count = 35 ; count > 0; count--) {
And same change for the other similar functions.
Offline Howardlong
« Reply #8 on: May 25, 2018, 10:05:44 pm »
Good spot.
