I made the following code in mikroC for PIC16F877A
float v, v1, v2, v_peak;
unsigned int adc1, adc2;
unsigned char l_byte, h_byte;
char ch1[5], ch2[5];
float ADR, adc;
unsigned short channel;
unsigned short current_status, prev_status;
/////* Definitions */////
#define v_rms_min 190 // lowest alloable RMS voltage
#define source_1 RD0_bit // source_1 @ pin RD0
#define source_2 RD1_bit // source_2 @ pin RD1
#define no_active_source RD2_bit // no_active_source indication LED @ pin RD2
#define source_1_on RD3_bit // source_1_on indication LED @ pin RD3
#define source_2_on RD4_bit // source_2_on indication LED @ pin RD4
// LCD module connections
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
// LCD text variables
char txt1[] = "V1 = ";
char txt2[] = "V2 = ";
char txt3[6] = " ";
char txt4[6] = " ";
char txt5[] = "V RMS";
unsigned int ADCRead(unsigned short channel){
if (channel == 0) {ADCON0 = 0x81;} // convert from channel0
if (channel == 1) {ADCON0 = 0x89;} // convert from channel1
delay_us(80); // Acquisition Delay
GO_DONE_bit = 1; // Set GO_DONE bit to start conversion
while (GO_DONE_bit == 1); // Wait for bit to be cleared
// If bit is cleared, conversion is over
l_byte = ADRESL;
h_byte = ADRESH;
ADR = (h_byte<<8)|l_byte;
return ADR;
float RMS_calculator (unsigned short source) {
channel = source; // pick source
adc = ADCRead(channel); // read ADC value
v = (adc*0.00488*7.66); // Determine voltage at ADC pin
if ( v < 0.11 ) {v = v*0.707*18.3;} // calculate RMS value
else {v = (v+1.2)*0.707*18.3;}
return v;
unsigned short check_status() {
if ( v1 >= v_rms_min ) { current_status = 1; }
else {
if ( v2 >= v_rms_min ) { current_status = 2; }
else { current_status = 3; }
return current_status;
void apply_status() {
switch ( current_status ) {
case 1:
source_2 = 0; // deactivate source_2
delay_ms(40); // wait 30ms
source_1 = 1; // activate source_1
source_2_on = 0; // source_2_on LED is OFF
source_1_on = 1; // source_1_on LED is ON
no_active_source = 0; // no_active_source LED is OFF
break;
case 2:
source_1 = 0; // deactivate source_1
source_2 = 1; // activate source_2
source_1_on = 0; // source_1_on LED is OFF
source_2_on = 1; // source_2_on LED is ON
break;
case 3:
source_1 = 0; // source_1 off
source_2 = 0; // source_2 off
no_active_source = 1; // no_active_source LED is ON
break;
void main() {
CMCON = 7; //Disable comparator
PORTA = 0;
TRISA = 0xff;
PORTD = 0;
TRISD = 0;
PORTC = 0;
TRISC = 0;
PORTB = 0;
TRISB = 0;
ADCON0 = 0x81;
ADCON1 = 0xC0; // all portA pins are analog // was 0xCE
INTE_bit = 0;
no_active_source = 1; // no_active_source LED is OFF
v1 = 0;
v2 = 0;
adc1 = 0;
adc2 = 0;
current_status = 3;
apply_status();
/// LCD initialization ///
Lcd_Init(); // Initialize LCD
delay_ms(10);
Lcd_Cmd(_LCD_CLEAR); // Clear display
delay_ms(10);
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
delay_ms(10);
Lcd_Out(1,1,txt1); // Write text in first row
delay_ms(10);
Lcd_Out(2,1,txt2); // Write text in second row
// option_reg=0b00101111;
while (1){
prev_status = current_status;
// calculate channel0 voltage
v1 = RMS_calculator (0);
//adc1 = ADR;
// calculate channel1 voltage
v2 = RMS_calculator (1);
// adc2 = ADR;
current_status = check_status();
if ( current_status != prev_status ) { apply_status(); }
delay_ms(100);
// display v1
floattostr(v1,ch1);
txt3[0] = ch1[0];
txt3[1] = ch1[1];
txt3[2] = ch1[2];
txt3[3] = ch1[3];
txt3[4] = ch1[4];
Lcd_Out(1,6,txt3);
delay_ms(10);
Lcd_Out(1,12,txt5);
// display v2
floattostr(v2,ch2);
txt4[0] = ch2[0];
txt4[1] = ch2[1];
txt4[2] = ch2[2];
txt4[3] = ch2[3];
txt4[4] = ch2[4];
Lcd_Out(2,6,txt4);
delay_ms(10);
Lcd_Out(2,12,txt5);
}RD0_pin should be ON when 5v is at RA0.
RD1_pin should be ON when 5v is at RA1 and no voltage at RA0.
RD2_pin is ON when no voltage at RA0 and RA1.
the problem is RD0_pin won't go ON at it's condition! and the other 2 ones are correct!
I ran the simulation in Proteus ISIS, and it worked but made some errors... like the following:
so what happens?
please check my subroutine called check_status because it's the one that decide which pin to be active.
I attached the hex file.
