Author Topic: PIC18F2550 Interrupt Timing ???  (Read 4514 times)
Offline MarkFTopic starter
« on: April 18, 2016, 01:38:31 am »
What am I missing here?
I'm trying to setup a 100 Hz interrupt for a pic18f2550 but getting a 200 Hz interrupt.
   Design data:
      8 MHz internal clock
      0x1388 = 5000 count match for Comparator count
   Measured clocks:
      OSC2 = 2 MHz
      RA5 bit = 200 Hz  (interrupt clock)
I have done similar interrupt timing for a pic16f876 without issue.
   Design data:
      20 MHz external clock
      0x0140 = 320 count match
   Measured clock:
      15.82 KHz (interrupt clock)
PIC18F2550 code snippet:
#include <xc.h>
#include <stdint.h>
#include <stdio.h>
#include <math.h>
#include "xtal.h"
// CONFIGURATION BITS
// CONFIG1L
#pragma config PLLDIV = 5           // PLL Prescaler Selection bits (Divide by 5 (20 MHz oscillator input))
#pragma config CPUDIV = OSC1_PLL2   // System Clock Postscaler Selection bits ([Primary Oscillator Src: /1][96 MHz PLL Src: /2])
#pragma config USBDIV = 1           // USB Clock Selection bit (used in Full-Speed USB mode only; UCFG:FSEN = 1) (USB clock source comes directly from the primary oscillator block with no postscale)
// CONFIG1H
#pragma config FOSC = INTOSC_EC     // Oscillator Selection bits (Internal oscillator, CLKO function on RA6, EC used by USB (INTCKO))
#pragma config FCMEN = OFF          // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
#pragma config IESO = OFF           // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
// CONFIG2L
#pragma config PWRT = ON            // Power-up Timer Enable bit (PWRT enabled)
#pragma config BOR = OFF            // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
#pragma config BORV = 3             // Brown-out Reset Voltage bits (Minimum setting 2.05V)
#pragma config VREGEN = OFF         // USB Voltage Regulator Enable bit (USB voltage regulator disabled)
// CONFIG2H
#pragma config WDT = OFF            // Watchdog Timer Enable bit (WDT disabled (control is placed on the SWDTEN bit))
#pragma config WDTPS = 32768        // Watchdog Timer Postscale Select bits (1:32768)
// CONFIG3H
#pragma config CCP2MX = OFF         // CCP2 MUX bit (CCP2 input/output is multiplexed with RB3)
#pragma config PBADEN = OFF         // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
#pragma config LPT1OSC = OFF        // Low-Power Timer 1 Oscillator Enable bit (Timer1 configured for higher power operation)
#pragma config MCLRE = OFF          // MCLR Pin Enable bit (RE3 input pin enabled; MCLR pin disabled)
// CONFIG4L
#pragma config STVREN = ON          // Stack Full/Underflow Reset Enable bit (Stack full/underflow will cause Reset)
#pragma config LVP = OFF            // Single-Supply ICSP Enable bit (Single-Supply ICSP disabled)
#pragma config XINST = OFF          // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
int8_t en0;
uint8_t sw0,sw1,sw2;
uint8_t currA0,lastA0;
uint8_t fUpdate=0;
uint16_t vBat;
uint8_t ddsM;
float ddsF1,ddsF2;
float ddsP1,ddsP2;
float ddsA;
float ddsT;
void main()
   TRISA=0b11000001;       // Set Port A direction bits
   TRISB=0b11100101;       // Set Port B direction bits
   TRISC=0b01111111;       // Set Port C direction bits
   OSCCON=0x72;            // Select internal oscillator @ 8MHz
   ADCON0=0;               // A/D converter off
   ADCON1=0x0f;            // All digital inputs
   INTCON2bits.nRBPU=1;    // Port B pull-ups disabled
   UCON=0x00;              // USB module and supporting circuitry disabled
   UCFG=0x08;              // On-chip USB transceiver disabled
   PORTA=0xff;
   PORTB=0xff;
   // Setup battery monitor
   ADCON0=0x01;            // A/D converter on
   ADCON1=0x0e;            // AN0 only
   ADCON2=0x91;            // Right justified | 4*Tad | Fosc/8  (for 8 MHz system clock)
   // Setup rotary encoder
   en0=0;
   sw0=sw1=sw2=0;
   lastA0=PORTCbits.RC1;
   // Setup CCP1 configuration
   CCPR1H=0x13;                  // 100 Hz interrupt
   CCPR1L=0x88;
   CCP1CON=0x0b;                 // Compare mode, trigger special event
   // Setup Timer3 configuration
   TMR3H=0;
   TMR3L=0;
   T3CON=0x55;                   // T3CCP | 1:4 Prescale | TMR3CS | TMR3ON bits
   // Enable CCP1 interrupt
   PIR1bits.CCP1IF=0;            // CCP2 Interrupt Flag bit
   PIE1bits.CCP1IE=1;            // CCP2 Interrupt Enable bit
   INTCON=0xc0;                  // GIE and PEIE interrupts
   while (1) {
      // Read battery voltage
      ADCON0bits.GO=1;
      while (ADCON0bits.nDONE);
      vBat = (uint16_t)ADRESH << 8 | (uint16_t)ADRESL;
      ddsA = 5.0 * (float)vBat / 1024.0;
      // Process encoder inputs
      if (en0 > 0)
         ddsF1 += pow(10.,abs(en0)-1);
      else if (en0 < 0)
         ddsF1 -= pow(10.,abs(en0)-1);
      en0=0;
void interrupt isr()
   if (PIE1bits.CCP1IE && PIR1bits.CCP1IF) {
      PIR1bits.CCP1IF = 0;    // clear CCP1 Interrupt Flag
LATAbits.LA5 = 0;
      // Read rotary encoder
      currA0=PORTCbits.RC1;
      if (lastA0==0 && currA0==1) {
         if (PORTCbits.RC2==1) en0--; else en0++;
      lastA0=currA0;
      if (PORTCbits.RC0==0) sw0=1;
      if (PORTCbits.RC4==0) sw1=1;
      if (PORTCbits.RC5==0) sw2=1;
LATAbits.LA5 = 1;
« Last Edit: April 18, 2016, 02:27:17 am by MarkF »
Offline Skimask
Re: PIC18F2550 Interrupt Timing ???
« Reply #1 on: April 18, 2016, 05:50:54 am »
Check that...
Looks to me like you set a 1:2 prescale.
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
Offline dannyf
« Reply #2 on: April 18, 2016, 10:55:02 am »
"PIC18F2550 code snippet:"
1. I typically work on the bit or mask levels, with comments so it can be traced easily during debug and for future reuses.
2. I would put those code that initializes the adc or timers in separate routines so they can be reused later in other programs.
« Reply #3 on: April 18, 2016, 12:54:10 pm »
Check that...
I would agree if this was Timer 1; but this is Timer 3 and the bit layout is different.
Offline android
« Reply #4 on: April 18, 2016, 01:26:26 pm »
Mikroelectronica have a free timer calculator that could be useful...generates c code of sorts:
http://www.mikroe.com/timer-calculator/
Lecturer: "There is no language in which a double positive implies a negative."
Student:  "Yeah...right."
Offline Skimask
« Reply #5 on: April 18, 2016, 01:39:59 pm »
Check that...
I dunno.  I'm looking at the datasheet for T1CON and T3CON right now.
T3CON = $55 = 01010101 = enable 16bit, T3 source for CCPx, PRESCALE 1:2, sync ext clk in, internal clk source, T3 enabled.
At any rate, would it hurt to try other prescale values to see how the interrupt timing changes?
« Last Edit: April 18, 2016, 01:41:34 pm by Skimask »
I turned it on.
« Reply #6 on: April 19, 2016, 03:03:08 am »
Check that...
The bit layout for T3CON is not what I expected.  T3CCP2:T3CCP1 is bits 3 and 6 instead of being next to one another.  And T3CKPS1:T3CKPS0 is bits 4 and 5.  I looked at it over and over and missed it every time.
« Last Edit: April 19, 2016, 03:13:54 am by MarkF »
Offline Skimask
« Reply #7 on: April 19, 2016, 04:20:23 am »
I blame Microchip.....because I can :D
I turned it on.
