Author Topic: PIC32 and ASM  (Read 10811 times)
Offline DominusDRRTopic starter
PIC32 and ASM
« on: May 15, 2014, 07:21:01 pm »
Hi.
Can anyone tell me where I can learn how to program the PIC32 microcontroller assembly language?
I prefer to do it by MPLAB X.
Thanks
 :-DD
Offline lewis
  • Nullius in verba
Re: PIC32 and ASM
« Reply #1 on: May 15, 2014, 08:07:15 pm »
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
Offline madshaman
  • ego trans insani
Re: PIC32 and ASM
« Reply #2 on: May 15, 2014, 08:18:33 pm »
Have you read the documentation for that uC?  It might have an instruction reference..
To be responsible, but never to let fear stop the imagination.
Offline westfw
Re: PIC32 and ASM
« Reply #3 on: May 15, 2014, 08:25:31 pm »
It's a MIPS core.  A lot of relatively recent "how to program in assembly language" and "computer architecture" classes have been based on MIPS. (after all, it originated in Academia.)
The MPLabX uses the gnu assembler, which has a lot of features independent of the target cpu, so learning any other gnu-as (gas) target may be useful.  (alas, gas is not a particularly user-oriented assembler :-( )
Offline andersm
Re: PIC32 and ASM
« Reply #4 on: May 15, 2014, 08:40:03 pm »
If you're familiar with assembly for some other architecture, you can go to ImgTec's website and download "MIPS Architecture For Programmers", volumes 1-3. The book "See MIPS Run" by Dominic Sweetman is a thorough coverage of the architecture, though it also covers a lot of things not relevant for microcontrollers. And as westfw said, a lot of academic courses use MIPS as example.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PIC32 and ASM
« Reply #5 on: May 15, 2014, 11:41:36 pm »
Seven Transistor Labs, LLC
Online nctnico
Re: PIC32 and ASM
« Reply #6 on: May 16, 2014, 12:06:21 am »
Hi.
Thanks
 :-DD
Read the instruction set reference and do not forget that a MIPS processor also executes the instruction after a jump before making the jump. Very annoying.
Offline andersm
Re: PIC32 and ASM
« Reply #7 on: May 16, 2014, 04:15:53 am »
ImgTec just released R6 of the architecture, and it actually removes the delay slot, among many other compatibility-breaking changes.
Offline PeterG
Re: PIC32 and ASM
« Reply #8 on: May 16, 2014, 06:59:43 am »
Testing one two three...
Offline neslekkim
  • Country: no
Re: PIC32 and ASM
« Reply #9 on: May 19, 2014, 01:18:49 pm »
Do you have an link to those three volumes?, I was looking around, but could not find much?
Offline andersm
Re: PIC32 and ASM
« Reply #10 on: May 19, 2014, 01:49:33 pm »
You can find them on ImgTec's website, but you may have to register first.
Offline neslekkim
  • Country: no
Re: PIC32 and ASM
« Reply #11 on: May 19, 2014, 02:05:02 pm »
ah, thanks!
Offline jlmoon
  • If you fail the first time, keep trying!
Re: PIC32 and ASM
« Reply #12 on: May 21, 2014, 04:58:47 pm »
Where's FogHorn-LegHorn when you need him?
Recharged Volt-Nut
Offline os40la
Re: PIC32 and ASM
« Reply #13 on: June 02, 2014, 06:50:07 pm »
"No, but I did stay at a Holiday Inn Express"
Offline Q-Kernel
Re: PIC32 and ASM
« Reply #14 on: June 09, 2014, 12:49:58 am »
I wrote assembler for the Open Source RTOS Q-Kernel. I would not recommend it is difficult to optimize the pipeline for the MIPS processor. Most C compilers generate code that performs better than assembler. If you want to try it anyway I would recommend the book from Morgan Kaufmann See.MIPS.Run
Offline Stonent
Re: PIC32 and ASM
« Reply #15 on: June 10, 2014, 12:29:13 pm »
Got any more of them long haired books, boy?
Offline jlmoon
Re: PIC32 and ASM
« Reply #16 on: June 10, 2014, 09:06:34 pm »
LOL..  :-DD  Great Show!
Recharged Volt-Nut
Offline SolarSunrise
  • Country: ua
  • Hi there!
Re: PIC32 and ASM
« Reply #17 on: June 13, 2014, 07:48:03 pm »
Assembly ain't that complicated. Heck that picture probably represents .NET  :scared:
