Hello
I have a PIC32MZ1024EFG064 and I am programming in C++. I haven't done much C++ before, but I have done a fair amount of C before. The compiler is saying no errors, everything looks ok. I can get code to work in the main, just the timer2 interrupt will not work. Here is much code:
#include "p32mz1024efg064.h"
#include <xc.h>
#include <stdio.h>
#include <stdlib.h>
#include <sys/attribs.h>
#include <stdint.h> /* For uint32_t definition */
#include <stdbool.h> /* For true/false definition */
// PIC32MZ1024EFG064 Configuration Bit Settings
// 'C' source line config statements
// DEVCFG3
// USERID = No Setting
#pragma config FMIIEN = OFF // Ethernet RMII/MII Enable (MII Enabled)
#pragma config FETHIO = ON // Ethernet I/O Pin Select (Default Ethernet I/O)
#pragma config PGL1WAY = OFF // Permission Group Lock One Way Configuration (Allow only one reconfiguration)
#pragma config PMDL1WAY = ON // Peripheral Module Disable Configuration (Allow only one reconfiguration)
#pragma config IOL1WAY = ON // Peripheral Pin Select Configuration (Allow only one reconfiguration)
#pragma config FUSBIDIO = OFF // USB USBID Selection (Controlled by the USB Module)
// DEVCFG2
#pragma config FPLLIDIV = DIV_1 // System PLL Input Divider (1x Divider)
#pragma config FPLLRNG = RANGE_8_16_MHZ // System PLL Input Range (8-16 MHz Input)
#pragma config FPLLICLK = PLL_FRC // System PLL Input Clock Selection (POSC is input to the System PLL)
#pragma config FPLLMULT = MUL_8 // System PLL Multiplier (PLL Multiply by 8)
#pragma config FPLLODIV = DIV_2 // System PLL Output Clock Divider (2x Divider)
#pragma config UPLLFSEL = FREQ_24MHZ // USB PLL Input Frequency Selection (USB PLL input is 24 MHz)
// DEVCFG1
#pragma config FNOSC = FRCDIV // Oscillator Selection Bits (Primary Osc (HS,EC))
#pragma config DMTINTV = WIN_127_128 // DMT Count Window Interval (Window/Interval value is 127/128 counter value)
#pragma config FSOSCEN = OFF // Secondary Oscillator Enable (Disable SOSC)
#pragma config IESO = OFF // Internal/External Switch Over (Enabled)
#pragma config POSCMOD = HS // Primary Oscillator Configuration (HS osc mode)
#pragma config OSCIOFNC = OFF // CLKO Output Signal Active on the OSCO Pin (Disabled)
#pragma config FCKSM = CSDCMD // Clock Switching and Monitor Selection (Clock Switch Enabled, FSCM Enabled)
#pragma config WDTPS = PS1048576 // Watchdog Timer Postscaler (1:1048576)
#pragma config WDTSPGM = STOP // Watchdog Timer Stop During Flash Programming (WDT stops during Flash programming)
#pragma config WINDIS = NORMAL // Watchdog Timer Window Mode (Watchdog Timer is in non-Window mode)
#pragma config FWDTEN = OFF // Watchdog Timer Enable (WDT Disabled)
#pragma config FWDTWINSZ = WINSZ_25 // Watchdog Timer Window Size (Window size is 25%)
#pragma config DMTCNT = DMT31 // Deadman Timer Count Selection (2^31 (2147483648))
#pragma config FDMTEN = OFF // Deadman Timer Enable (Deadman Timer is disabled)
// DEVCFG0
#pragma config DEBUG = OFF // Background Debugger Enable (Debugger is disabled)
#pragma config JTAGEN = OFF // JTAG Enable (JTAG Disabled)
#pragma config ICESEL = ICS_PGx1 // ICE/ICD Comm Channel Select (Communicate on PGEC1/PGED1)
#pragma config TRCEN = ON // Trace Enable (Trace features in the CPU are enabled)
#pragma config BOOTISA = MIPS32 // Boot ISA Selection (Boot code and Exception code is MIPS32)
#pragma config FECCCON = OFF_UNLOCKED // Dynamic Flash ECC Configuration (ECC and Dynamic ECC are disabled (ECCCON bits are writable))
#pragma config FSLEEP = OFF // Flash Sleep Mode (Flash is powered down when the device is in Sleep mode)
#pragma config DBGPER = PG_ALL // Debug Mode CPU Access Permission (Allow CPU access to all permission regions)
#pragma config SMCLR = MCLR_NORM // Soft Master Clear Enable bit (MCLR pin generates a normal system Reset)
#pragma config SOSCGAIN = GAIN_2X // Secondary Oscillator Gain Control bits (2x gain setting)
#pragma config SOSCBOOST = OFF // Secondary Oscillator Boost Kick Start Enable bit (Normal start of the oscillator)
#pragma config POSCGAIN = GAIN_1X // Primary Oscillator Gain Control bits (2x gain setting)
#pragma config POSCBOOST = ON // Primary Oscillator Boost Kick Start Enable bit (Boost the kick start of the oscillator)
#pragma config EJTAGBEN = NORMAL // EJTAG Boot (Normal EJTAG functionality)
// DEVCP0
#pragma config CP = OFF
unsigned int i = 0;
unsigned int a = 0;
using namespace std;
extern "C"
void __ISR_AT_VECTOR (_TIMER_2_VECTOR, IPL2SOFT) T2Interrupt(void){
IFS0bits.T2IF=0; //Clear the flag
LATB=LATB^0x2000; //Flip the output
int main(void)
//Osc config
//OSCCON = 0x21100; //system PLL
//SPLLCON = 0x30004; //PLL Multiply by 4, 21-42MHz range (32MHz)
PB2DIV = 0x8003; //Clock div for UART clock, Div = 4, CLK = 8MHz
PB3DIV = 0x8000; //Bus for timers
TRISB=0;
//Timer 2
PR2 = 1000; //
TMR2 = 0;
T2CON = 0x8000; //Timer on
IPC2bits.T2IP=2; //Priority 2
IEC0bits.T2IE=1; //Enable interrup
while(1)
There is so little help online. Why aren't there more code examples online!?!?!?
This is the sample code which comes with MPLAP X, I don't know what half of it is doing:
#include <xc.h>
#include <cp0defs.h>
#include <iostream>
// Configuration Bit settings
// SYSCLK = 80 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
// PBCLK = 40 MHz
// Primary Osc w/PLL (XT+,HS+,EC+PLL)
// WDT OFF
// Other options are don't care
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_1
#define CORE_TICK_RATE 1000000u
volatile unsigned long my_count = 0;
// An ISR must be in the "C" namespace.
extern "C"
void __ISR(_CORE_TIMER_VECTOR, IPL2SOFT) CoreTimerHandler(void)
unsigned long old_count, period;
old_count = _CP0_GET_COUNT();
// clear the interrupt flag
IFS0CLR = _IFS0_CTIF_MASK;
// .. things to do
cout << "Executing CoreTimerHandler #" << my_count++ << endl;
// update the period
period = CORE_TICK_RATE;
period += old_count;
_CP0_SET_COMPARE(period);
int __attribute__((nomips16)) main (void)
unsigned int cause_val;
// Add code to configure cache, wait states, and peripheral bus clock
// See http://www.microchip.com/mplabharmony
// Set stdout to go to UART 1 instead of UART 2
__XC_UART=1;
cout << "Beginning " __FILE__ " test" << endl;
// Configure the core timer
// clear the count reg
_CP0_SET_COUNT(0);
// set up the period in the compare reg
_CP0_SET_COMPARE(CORE_TICK_RATE);
// The Core timer should halt when we are halted at a debug breakpoint.
_CP0_BIC_DEBUG(_CP0_DEBUG_COUNTDM_MASK);
// set up the core timer interrupt with a prioirty of 2 and zero sub-priority
IPC0CLR = _IPC0_CTIP_MASK;
IPC0SET = (2 << _IPC0_CTIP_POSITION);
IPC0CLR = _IPC0_CTIS_MASK;
IPC0SET = (0 << _IPC0_CTIS_POSITION);
IEC0CLR = _IEC0_CTIE_MASK;
IEC0SET = (1 << _IEC0_CTIE_POSITION);
// enable multi-vector interrupts
// set the CP0 cause IV bit high
cause_val = _CP0_GET_CAUSE();
cause_val |= _CP0_CAUSE_IV_MASK;
_CP0_SET_CAUSE(cause_val);
INTCONSET = _INTCON_MVEC_MASK;
// set the CP0 status IE bit high to turn on interrupts
__asm__ volatile ("ei");
while(1) {
__asm__ volatile ("nop");
Any insight as to why it isn't working would be much appreciated!
