Author Topic: Pickit 5 - ICD5  (Read 33859 times)
Offline SiliconWizard
Re: Pickit 5 - ICD5
« Reply #25 on: May 24, 2023, 07:15:29 pm »
Too bad MPLAB has become a disaster. :-//
in what way?
In almost every way. But considering what had just be pointed out earlier, the infamous "transmission failed on endpoint 2" is absolutely nothing new. It has plagued MPLAB X for years with several different generations of ICDx and Pickitx, which would point to MPLAB itself rather than the hardware, especially since those communication issues are almost non-existent using IPE.
I've seen this problem for years on various OSs and various versions of MPLAB and programming probes.
This thread came at a funnily appropriate time: https://www.eevblog.com/forum/microcontrollers/flashing-pic-uc-without-mplab-(i-have-a-pickit)/
Anyway, it's really about flashing devices, and there is IPE for this. Otherwise one can absolutely do without MPLAB to develop for all they MCUs, something that a few of us here recommend on a regular basis. It's not specific to Microchip, most vendor-provided IDEs are crap.
Offline jpanhalt
Re: Pickit 5 - ICD5
« Reply #26 on: May 24, 2023, 08:02:55 pm »
It is good that they do still support icd3 on mplab8
That's only a "sorta."  The chip I was using for a just finished project was 16F1789 ( I wanted extra pins for routing).  That chip has a glaring error in the MCC .inc file.  Moreover, programming with the most recent .jam file and ICD3 was problematic.  My correspondence generally began with MCC telling me to install MPLAB X.  Later, a kind agent gave me a link to a legacy .jam file and everything has worked since.
Offline IDEngineer
Re: Pickit 5 - ICD5
« Reply #27 on: May 25, 2023, 01:00:14 am »
They suggested sticking to pickit3/icd3 for win7.
I'm happy to follow their advice. Where on their website do I purchase new ICD3's to do so?
Offline westfw
Re: Pickit 5 - ICD5
« Reply #28 on: May 25, 2023, 02:04:00 am »
it was not possible to get to a 64bit executable of MPASM without a complete rewrite.
Was it written entirely in assembly language?  Otherwise I'm not sure I understand how that's possible!
We've been through this many times.
Reference? (I don't recall seeing the discussion.)
Not being backwards-compatible with 30-odd years of existing assembly code seems like a huge mistake.
Who knows how long the older MPASM toolchain will continue to run on "modern" PCs.
(Is there a third-party (preferably open source) MPASM-compatible available?  After all, there are at least 3 Atmel-compatible AVR assemblers...)
Offline JPortici
Re: Pickit 5 - ICD5
« Reply #29 on: May 25, 2023, 05:33:53 am »
"We've been through this" over at the microchip forum, at least. It's written in a flavour of pascal for which the compiler has been defuct for ages, and that couldn't be compiled directly with another compiler that was able to produce a 64bit executable (and i believe they tried. As you and others pointed out over the years there is a ton of legacy code written for MPASM that can't be easily translated into PIC-AS, i also mentioned i know of very big customers of them that still use MPASM to date)
i believe GPUTILS/GPASM is what you're looking for?
Offline jpanhalt
Re: Pickit 5 - ICD5
« Reply #30 on: May 25, 2023, 09:19:31 am »
Interesting link.  I found this comment encouraging:
Source:
https://gputils.sourceforge.io/
Jan 30, 2022 -- gputils-1.5.2 Released
New experimental gplink features: banksel, pagesel and pcallw
Support for more PIC16F184XX devices.
A few minor bugfixes.
So, although development may be slow and apparently led by only one person, it is not dead.
Offline jpanhalt
Re: Pickit 5 - ICD5
« Reply #31 on: May 25, 2023, 09:22:48 am »
I suspect new ones will be very hard to fine.  eBay may be your only choice.
Offline blubillcanada
Re: Pickit 5 - ICD5
« Reply #32 on: July 05, 2023, 03:08:55 pm »
The micro USB connector is garbage on the PICKit 4, I've gone through replacing three of them at the office. USB C is much better. I still use the old reliable ICD3 sometimes.
Offline JPortici
Re: Pickit 5 - ICD5
« Reply #33 on: July 05, 2023, 05:55:17 pm »
true. replaced yet another one today. I wish they'd update the PK4 with a USB-C connector, for those who don't care about the bluetooth part
I also wish someone would release a drop-in type C connector for USB 2.0 with the same pinout as the Micro B/C, with integrated 5.1k resistors
Re: Pickit 5 - ICD5
« Reply #34 on: July 07, 2023, 01:51:36 pm »
Just got my PICkit 5 today, not sure how useful Bluetooth is yet as it's currently only programmer to go app iPhone / Android; the USB C connector is a win for sure.
Offline JPortici
Re: Pickit 5 - ICD5
« Reply #35 on: July 07, 2023, 03:44:10 pm »
I think that's the idea, what were you expecting?
Re: Pickit 5 - ICD5
« Reply #36 on: July 07, 2023, 04:08:39 pm »
I guess I was hoping you could program & debug from MPLABX using Bluetooth, similar to Ethernet on the ICD5.
Offline slugrustle
Re: Pickit 5 - ICD5
« Reply #37 on: July 14, 2023, 12:42:15 am »
The deprecation of MPASM really bothered me, but I've gotten more or less used to PIC-AS since.  The issue above with the Pascal variant and support for x86-64 is fascinating.  It's crazy how quickly software can go out of date...  There's probably also an argument to be made for using open toolchains whenever possible in there somewhere.
Offline JPortici
Re: Pickit 5 - ICD5
« Reply #38 on: July 14, 2023, 05:15:25 am »
then you're free to use GNUASM :D (I'm joking, I 100% agree on the necessity to always have a usable open source tool, but at least microchip doesn't have a track record of being huge dicks to customers so i have no problem in using their tools exclusively for the time being)
IIRC the real nail into the coffin was the PIC18 Q series. MPASM had a harcoded maximum number of configuration words, which the PIC18 Q exceeded. At that point they had to change and recompile the thing, couldn't to it anymore, and threw the towel. Or something like that
Offline westfw
Re: Pickit 5 - ICD5
« Reply #39 on: September 04, 2023, 04:56:44 am »
I don't think gnuasm supports PIC8...
I've seen conflicting opinions.  Deprecating an assembler without a compatible replacement seems pretty bad.  Hardware programmers also seem to have a pretty short life.  (PicKit4 just declared EOL, for instance.)
Then there's the privatization of OSSW (gnu C for AVR, and 16 and 32bit PICs), the disappearance of avr-libc, and the occasionally VERY sub-optimal "free" versions of 8bit PIC C compilers.
Offline JPortici
Re: Pickit 5 - ICD5
« Reply #40 on: September 04, 2023, 05:54:55 am »
Yes, it was GPASM, my bad
For the rest, i don't have the energy to repeat myself again but i'll try.
you should install the latest compilers, write some meaningful code (something that uses pointers, mixed address spaces, interrupts, not bullshit tests to see how fast you can flip a pin), remind yourself that you are writing C and not assembly (of course with assembly you can write it "better") and really tell me it doesn't produce good code. If not, enable -O1 or -O2 and retry.
MPLABX 5.35, always available at the microchip archives, has the latest MPASM in it.
PK4 EOL didn't make sense, they should have just sold it as PK5 without the BLE module, for the rest is same board, same firmware.
Offline MerlinEmbedded
Re: Pickit 5 - ICD5
« Reply #41 on: December 18, 2023, 02:04:04 pm »
Many professionals, including me, still run Win7 due to its rock-solid reliability and stability. Microchip needs to insure compatibility with Win7, period. There's just too many people out there who run it.
In mid 2023? Windows 7 was essentially discontinued in 2012 and even extended support ended at the end of 2019. Whilst I can really sympathise with people needing to support their legacy assembler products, anyone using MPASM for new designs or using Windows 7, 8 or 10 machines for their new designs are just asking for trouble. There's no need to create a time capsule environment when developing new designs.
Whilst Windows 8 was a bit of a miss, Windows 10 has been a pleasure and I now enjoy productive development on Windows 11 for a variety of hardware design and both embedded and desktop software. Equally, anyone still using assembly to write code for PICs in 2023 are probably missing a trick. I am just working on a project written in 2015 in assembler. It was written in assembler for no reason at all and is now just a pain to maintain. No assembler IDE has ever been very good. No assembler build process has ever been very good. I'd say that  even with a poor modern compiler, using assembly has been questionable for the last 15 years.
Let's hope Microchip release the PicKit3 as an open source project like they did with the 1 and 2. At least then it could be used with a VM or workstation that isn't connected to the network to maintain older code that isn't worth rewriting.
Offline IDEngineer
Re: Pickit 5 - ICD5
« Reply #42 on: December 18, 2023, 04:49:18 pm »
Has nothing to do with Assembler, and everything to do with a stable environment that the USER controls. My wife and son both use multiple Win10 and Win11 PC's and they are constantly plagued by "updates" at inconvenient times, with those updates often "helpfully" changing system settings in an "I know better than you do" fashion that can take hours to unravel.
Another example: I have a friend with a private medical practice that runs on software hosted on Windows. A network of PC's, one in each exam room plus the front desk and individual doctor's and nurse's offices. When that medical office software package forced them to upgrade to Win10 (and now Win11) his totally stable environment went to @#$^& and now, every time Microsoft deems it useful to them to upgrade their machines, their office more or less shuts down for half a day while the staff sits on the phone with the app vendor resetting everything that the Microsoft "upgrade" changed.
This isn't a religious thing for me. I just want tools that *I* control, that *I* can configure and which stay that way, so that my tools don't get in the way of what I'm actually trying to accomplish. I don't get paid to handle Microsoft's decisions but I and others often DO lose valuable time having to unwind the damage those decisions cause. I don't mind the GUI changes (though those often seem gratuitous too). If Microsoft would stop compelling "updates" and other post-Win7 behavior I'd happily update every machine I own/control.
Offline IDEngineer
Re: Pickit 5 - ICD5
« Reply #43 on: December 20, 2023, 02:00:34 pm »
True to form, Microsoft provides another example just yesterday!
In this link:
https://arstechnica.com/gadgets/2023/12/microsoft-releases-downloadable-tool-to-fix-phantom-hp-printer-installations/
...we read "Affected PCs were seeing an HP printer installed, usually an HP LaserJet M101-M106, even when they weren’t actually using any kind of HP printer. This bug could overwrite the settings for whatever printer the user actually did have installed and also prompted the installation of an HP Smart printer app from the Microsoft Store."
Note that you get the machine mods without request, but YOU have to research the fix, then manually download and run it.
Yes, it was "just the printer". This time.
How many professionals want this happening to a key tool upon which they rely every day? Why would you willingly subject yourself to this if you could avoid it?
