Author Topic: Atmega Pin to send Data  (Read 1823 times)
Offline yalectTopic starter
« on: December 26, 2017, 09:09:44 am »
I would like to ask you that I want to sand data 8 bits or (1 byte) out of Atmega 32 throw one Pin of Port  like Port b for example which it means serially I found some Ideas like using -and- operation logic to compare the Data with 1 logic and shifting that Data right or left for eight times I made example in C but it did't work.
may you provide me an Idea or simple in C example?
thank you
« Last Edit: December 26, 2017, 10:11:44 am by yalect »
Offline matseng
    • My Github
Re: Atmega Pin to send Data
« Reply #1 on: December 26, 2017, 10:24:52 am »
For UART or SPI data?  But the correct term for this is "bitbang" or "software serial" or "softserial". So a google for instance  ATMEGA BITBANG SPI should turn up some relevant codes for you to pursue.
Offline Nusa
« Reply #2 on: December 26, 2017, 11:18:21 am »
Perhaps this will help. Didn't test. If I typoed something, sorry.
void setup() {
  pinMode(LED_BUILTIN, OUTPUT);
void loop() {
  int bits = 12345; // binary 0011 0000 0011 1001
  // use bits to flash built-in LED on a 1-second cycle
  for (int index = 0; index < 16; index++)
    if ((bits >> index) & 1) // shift right, then mask bottom bit
      // if bit was 1, give long flash on LED
      digitalWrite(LED_BUILTIN, HIGH);
      delay(900);
      digitalWrite(LED_BUILTIN, LOW);
      delay(100);
    else
      // if bit was 0, give short flash on LED
      delay(100);
      delay(900);
  delay(5000); wait 5 seconds, then repeat.
