Author Topic: Problem debugging PIC18F87J11 micro controller in assembly  (Read 2688 times)
Offline m.joTopic starter
« on: December 06, 2014, 05:28:04 am »
 The object of the code is to program a collision avoidance car that will only be going forward.  This is to be accomplished by using the PWM to create two signals, one that goes to the left side of the car and one that goes to the right side of the car.  These signals will slow the duty cycle of the side in question, causing the car to turn.
The way we know that the car needs to turn is by using 3 distance sensors that are shown in the add on document.
The problems that we are currently having with the code is a matter of scaling, getting the car to make decisions, and of a more immediate concern, the fact that while working with the code, all of a sudden the sensors stopped working and as far as we could tell the problem did not occur in the car or the equipment we used to attach the car to the computer.
We are using the MPLABX compiler, using the PIC18F87J11 micro controller, and are required to use assembly language to program this thing.
ANY HELP IS wonderful.  The project is due Wednesday and we are getting frustrated.
Here is the code:
   #ifdef __18F87J11
   list p=18F87J11
   #include p18F87J11.inc
    CONFIG   FOSC = HSPLL
   CONFIG STVREN = OFF,XINST = OFF,WDTEN = OFF,CP0 = OFF,FCMEN = OFF,IESO = OFF
   CONFIG      MODE = MM
#else
    Create error
#endif
STARTUP CODE 0
PROG1    CODE 0x18
;--------------------------------------------------------Memory-declarations
#define COUNT 0xFF
#define counter 0x0E
#define FRONTPINGH 0x10
#define FRONTPINGL 0x11
#define LEFTPINGH 0x00
#define LEFTPINGL 0x01
#define RIGHTPINGH 0x20
#define RIGHTPINGL 0x21
#define SCALEFACTORR 0x22
#define SCALEFACTORM 0x12
#define SCALEFACTORL 0x02
#define SCALEDHIGHL 0x03
#define SCALEDHIGHM 0x13
#define SCALEDHIGHR 0x23
#define SCALEDLOWL 0x04
#define SCALEDLOWM 0x14
#define SCALEDLOWR 0x24
#define RESULT 0x05
#define MEASUREH 0x06
#define MEASUREL 0x07
#define numerator 0x16
#define denominator 0x17
;--------------------------------------------------------Macros-------------
GETFRONTDIST MACRO
    bsf PORTF,2        ;go high front trigger pin
    movlw 0x05
    movwf COUNT        ;set number of times to run Countdown 5=10us
    call Countdown
    bcf PORTF,2        ;go low front trigger pin
frontpulse btfss PORTG,1           ;look for rising edge
    bra frontpulse
    bsf T0CON,7
endpulse   btfsc PORTG,1           ;look for falling edge
    bra endpulse
    bcf T0CON,7
    movff TMR0L, FRONTPINGL
    movff TMR0H, FRONTPINGH        ;Store timer count
    movlw 0x00
    movwf TMR0H
    movwf TMR0L
    ENDM
GETLEFTDIST MACRO
    bsf PORTF, 3
    movlw 0x05
    movwf COUNT
    call Countdown
    bcf PORTF,3
leftpulse btfss PORTG,2
    bra leftpulse
    bsf T0CON,7
endleftpulse btfsc PORTG,2
    bra endleftpulse
    bcf T0CON,7
    movff TMR0L, LEFTPINGL
    movff TMR0H, LEFTPINGH
    movlw 0x00
    movwf TMR0H
    movwf TMR0L
    ENDM
GETRIGHTDIST MACRO
    bsf PORTF,1
    movlw 0x05
    movwf COUNT
    call Countdown
    bcf PORTF,1
rightpulse btfss PORTG,0
    bra rightpulse
    bsf T0CON,7
endrightpulse   btfsc PORTG,0
    bra endrightpulse
    bcf T0CON,7
    movff TMR0L, RIGHTPINGL
    movff TMR0H, RIGHTPINGH
    movlw 0x00
    movwf TMR0H
    movwf TMR0L
    ENDM
Start:
    movlw 0x00          ;setup tris registers and tablepointer to 0
      movwf TRISF
    movwf TRISD
    movwf TBLPTRU
    movwf TBLPTRH
    bsf TRISA, 0
    bsf TRISA, 1
    bsf TRISB, 0
    movlw 0x02
    movwf TBLPTRH       ;using low byte for reference
   movlw 0xFF
   movwf TRISG
   movlw 0x03
   movwf T0CON    ;set Timer0 to 16-bit, internal clock, 1:256 scaler
    clrf TMR0H
    clrf TMR0L
    movlw 0xB5
    movff WREG, SCALEFACTORR            ; option to set dvalefactor
    movff WREG, SCALEFACTORL
    movlw 0xFF
    movff WREG, SCALEFACTORM
    movlw 0x04                             ;0x55 for leds, 0x08 for temp pot
    movff WREG, denominator
    movlw 0xB4
    movwf ADCON1
MainLoop:
    clrf RESULT
    GETFRONTDIST
    GETLEFTDIST
    GETRIGHTDIST
    call Scaleright
    call Scaleleft
    call Scalefront
    movff SCALEDHIGHL, WREG
    subwf SCALEDHIGHR, 0
    movwf RESULT
    movff RESULT, numerator
    bn sub
    goto add
sub
    movlw 0x03
    movwf TBLPTRL
    call Divide
    movff counter, WREG
    subwf TBLPTRL, 1
    bra done
add
    movlw 0x03
    movwf TBLPTRL
    call Divide
    movff counter, WREG
    addwf TBLPTRL, 1
done
;----------------------------------------------------------------AD Converters
    btfss PORTB, 0
        call PotCheck
    btfsc PORTB, 0                              ;finger heat scale index
        call TempCheck
button
;----------------------------------------------------------------sensor LEDS
 ;;   TBLRD*
;    MOVFF TABLAT, PORTD
 ;   movlw 0xff
  ;  movff WREG, COUNT
 ;   call Countdown
    bra MainLoop
   ;call Endhard
Divide:
    movff denominator, WREG
    subwf numerator, 0
    bn jump
    movff WREG, numerator
    incf counter
    bra Divide
jump
    return
PotCheck:
    movlw 0x01
    movff WREG, ADCON0
    bcf PIR1, 6
    bsf ADCON0, 1
here     btfss PIR1, 6
         bra here
    movff ADRESL, WREG
    movff WREG, MEASUREL
    movff ADRESH, WREG
    movff WREG, MEASUREH
    BCF STATUS, C
    rrcf MEASUREH
    rrcf MEASUREL
    BCF STATUS, C
    rrcf MEASUREH
    rrcf MEASUREL
    movff MEASUREL, PORTD
    return
TempCheck:
    movlw 0x05
    movff WREG, ADCON0
    bcf PIR1, 6
    bsf ADCON0, 1
there    btfss PIR1, 6
         bra there
    movff ADRESH, WREG
    movff ADRESL, WREG
    movff MEASUREH, numerator
    clrf counter
    call Divide
    movlw 0x08
    movff WREG, TBLPTRL
    movff counter, WREG
    addwf TBLPTRL, 1
    TBLRD*
    movff TABLAT, WREG
    mullw 0x02
    movff PRODL, WREG
    addlw 0x20
    movff WREG, PORTD
    return
Countdown:
    nop
    nop
    decf COUNT
    bnz Countdown
    return
Scaleleft:
    movff LEFTPINGL, WREG
    mulwf SCALEFACTORL
    movff PRODL, SCALEDLOWL
    movff PRODH, SCALEDHIGHL
    return
Scaleright:
    movff RIGHTPINGL, WREG
    mulwf SCALEFACTORR
    movff PRODL, SCALEDLOWR
    movff PRODH, SCALEDHIGHR
    return
Scalefront:
    movff FRONTPINGL, WREG
    mulwf SCALEFACTORM
    movff PRODL, SCALEDHIGHM
    movff PRODH, SCALEDLOWM
    return
;------------------------------------------------------------------------Tables
    CODE 0x200
lED DB 0x80, 0x60, 0x20, 0x18, 0x04, 0x06, 0x01
temp DB 0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b, 0x0c, 0x0d, 0x0e, 0x0f
     DB 0x10, 0x11, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18, 0x19, 0x1a, 0x1b, 0x1c, 0x1d, 0x1e, 0x1f
     DB 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x2a, 0x2b, 0x2c, 0x2d, 0x2e, 0x2f
     DB 0x30, 0x31, 0x32, 0x33, 0x34, 0x35, 0x36, 0x37, 0x38, 0x39, 0x3a, 0x3b, 0x3c, 0x3d, 0x3e, 0x3f
     DB 0x40, 0x41, 0x42, 0x43, 0x44, 0x45, 0x46, 0x47, 0x48, 0x49, 0x4a, 0x4b, 0x4c, 0x4d, 0x4e, 0x4f
     DB 0x50, 0x51, 0x52, 0x53, 0x54, 0x55, 0x56, 0x57, 0x58, 0x59, 0x5a, 0x5b, 0x5c, 0x5d, 0x5e, 0x5f
     DB 0x60, 0x61, 0x62, 0x63, 0x64, 0x65, 0x66, 0x67, 0x68, 0x69, 0x6a, 0x6b, 0x6c, 0x6d, 0x6e, 0x6f
     DB 0x70, 0x71, 0x72, 0x73, 0x74, 0x75, 0x76, 0x77, 0x78, 0x79, 0x7a, 0x7b, 0x7c, 0x7d, 0x7e, 0x7f
     DB 0x80, 0x81, 0x82, 0x83, 0x84, 0x85, 0x86, 0x87, 0x88, 0x89, 0x8a, 0x8b, 0x8c, 0x8d, 0x8e, 0x8f
Endhard:
 End
Offline westfw
Re: Problem debugging PIC18F87J11 micro controller in assembly
« Reply #1 on: December 06, 2014, 06:29:53 am »
Needs more comments.
Offline dannyf
« Reply #2 on: December 06, 2014, 12:16:40 pm »
If I were you, I would break down the code in to a few modules: two pwm generators for your left/right motors, three (potentially one if they are the same type of sensors) to read the sensors, and one to fuse the data together and calculate / update the pwm generators.
Assembly is useful if you are working on really simple things (blinking an led), or you are pushing the envelope of the mcu; aka you are a beginner or you are exceptionally gifted.
Anything in between, C wins.
