Author Topic: Problem decode UART on DSlogic  (Read 3964 times)
Offline arcticfishTopic starter
« on: September 05, 2019, 04:40:01 am »
Hi all,
Anyone has a DSlogic able to advise? I just bought a DSlogic to test out. To test this newly bought LA and the DSview whether it work as expected, I used a serial terminal software in my setup to send a ascii text "testing" to USB-RS485 device, then to the LA probe, and LA capture and send the reading to the DSview. The DSview was able to display 7 characters captured but it showed all zero on the data. Is there anything I did wrong?
You may refer to attachment for my setup.
Your advise is greatly appreciated
« Last Edit: September 05, 2019, 05:10:11 am by arcticfish »
Online Psi
Re: Problem decode UART on DSlogic
« Reply #1 on: September 05, 2019, 05:17:27 am »
RS485 is differential. I think that's your first problem.
I don't know much about DSlogic but i would assume the inputs are ground ref not differential.
The following users thanked this post: arcticfish
« Reply #2 on: September 05, 2019, 03:14:34 pm »
Thanks PSI. I got it, it was the differential wiring mistake.  |O
I still require some figuring how this software work. Not sure why the signal invert box has to be checked in DSview in order to see the corrected data.
Online Psi
« Reply #3 on: September 06, 2019, 04:16:54 am »
Some serial standards are inverted with respect to others.
So no matter what default they decide to use in the software someone will need invert enabled to get correct data.
