Author Topic: problem in string.h lib in codevision  (Read 1763 times)
Offline tariqTopic starter
  • Country: ir
« on: July 29, 2021, 07:46:30 pm »
hi
I'm using codevision AVR. in string.h lib when one of the arrays is const an error occurs.
for example i want to put a array of string from one array to another like this :
unsigned char A[11];
const unsigned char B[11]={"HELLOWORLD"};
when i use strncpy like this:
strncpy(A,B,10);
i have this error
Error:, #included from: main.c: function argument #2 of type 'flash unsigned char [11]' is incompatible with required parameter of type 'unsigned char *'
and this is the same for all of string.h lib functions.
in ARM and keil compiler i didn't had this problem but in codevision error occurs.
i know i can use for loop but is there any way to avoid this error?
Offline richmit
    • https://www.mitchr.me/
Re: problem in string.h lib in codevision
« Reply #1 on: July 29, 2021, 09:02:34 pm »
Offline esepecesito
« Reply #2 on: July 30, 2021, 05:16:37 pm »
When you made the constant, it will be placed in ROM (flash). The library seems not to be able to copy from flash to RAM.
I do not know what you are trying to do, to help with a workaround for it.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #3 on: July 30, 2021, 05:48:09 pm »
strncpy_P
Seven Transistor Labs, LLC
