Author Topic: problem with MPLAB Assembler  (Read 7142 times)
Offline RodHTopic starter
« on: February 10, 2013, 10:37:58 pm »
I have been attempting to compile the attached  program fragment and I get these error messages:
Error[126]   C:\PIC DOCUMENTS\MEDTIM.ASM 58 : Argument out of range (0008 not between 0005 and 0007)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 68 : Symbol not previously defined (two)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 70 : Symbol not previously defined (four)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 72 : Symbol not previously defined (six)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 74 : Symbol not previously defined (eight)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 76 : Symbol not previously defined (ten)
Error[113]   C:\PIC DOCUMENTS\MEDTIM.ASM 78 : Symbol not previously defined (twelve)
Here is part of the program:
   list    p=pic16f877
   radix   hex
;   #include   <p16f877>
;       cpu equates (memory map)
tmro   equ   0x01
porta   equ   0x05
portb   equ   0x06
portc   equ   0x07
portd   equ   0x08
porte   equ   0x09
intcon   equ   0x0c
second   equ   0x0e
minute   equ   0x10
hours   equ   0x12
minutes   equ   0x14
   org   0x00
   goto   start       ;skip interrupt vector
start
   org   0x004
   bcf   intcon,7    ;disable global interrupt
   movlw   b'000001'   ;setup port a
   tris   porta      ;setup port a 1=in,0=out
   movlw   b'000000'   ;clear porta
   movwf   porta
   movlw   b'00000111'   ;setup portb
   tris   portb      ;setup portb 1=in, 0=out
   movlw   b'00000000'   ;clear b
   movwf   portb
   movlw   b'00001100'   ;portc
   tris   portc      ;setup portc 1=in,0=out
   movlw    b'00000000'   ;clear c
   movwf    portc
   movlw   b'00000000'   ;setup d
   tris   portd
   movlw   b'00000000'   ;clear d
   movwf   portd
pgm
   clrw         ;clear w
   clrf   second      ;clear second count
   clrf   minute      ;clear minute count
   clrf   minutes      ;clear clock mintes
   clrf   hours      ;clear clock hours
   btfss   porta,5      ;test port a5, skip next if set(low active)
   goto   two
   btfss   portb,5      ;test portb5, skip next if set
   goto   four
   btfss   portb,6      ;test portb6
   goto   six
   btfss   portb,7      ;test portb7
   goto   eight
   btfss   portc,4      ;test portc4,skip next if set
   goto   ten
   btfss   portc,5      ;test portc5
   goto    twelve
   end
two
   movlw   b'00000000'   ;setting first digit
   wovwf   porta
   movlw   b'00100000'   ;setting second digit
   movwf   portb
   movlw   b'00000010'   ;loading hours
   movfw   hours
   movlw   b'00000000'   ;setting third digit
   movwf   portc
   movlw   b'00000000'   ;setting fourth digit
        movwf   portd
   movlw   b'00000000'   ;loading minutes
   movwf   minutes
   goto   clock
four
   wovwf   porta
   movlw   b'01000000'   ;setting second digit
   movwf   portb
   movlw   b'00000100'   ;loading hours
   movfw   hours
   movwf   portc
    movwf   portd
   movwf   minutes
   goto   clock
six
   wovwf   porta
   movlw   b'01100000'   ;setting second digit
   movwf   portb
   movlw   b'00000110'   ;loading hours
   movfw   hours
   movwf   portc
    movwf   portd
   movwf   minutes
   goto   clock
eight
   wovwf   porta
   movlw   b'10000000'   ;setting second digit
   movwf   portb
   movlw   b'00001000'   ;loading hours
   movfw   hours
   movwf   portc
    movwf   portd
   movwf   minutes
   goto   clock
ten
   movlw   b'00000001'   ;setting first digit
   wovwf   porta
   movlw   b'00000000'   ;setting second digit
   movwf   portb
   movlw   b'00001010'   ;loading hours
   movfw   hours
   movwf   portc
    movwf   portd
   movwf   minutes
   goto   clock
twelve
   wovwf   porta
   movwf   portb
   movlw   b'00001100'   ;loading hours
   movfw   hours
   movwf   portc
    movwf   portd
   movwf   minutes
   goto   clock
clock
   bsf   t1con,tmr1on   ;turn on timer 1
   bcf   t1con,tmr1cs   ;use internal 4mhz clock
   movlw   0x8
   movwf   t1ckps0      ;set prescale = 8
   bcf   t1con,t1ckps1   ;set division = 0
;   movlw   b'00110001'
;   movwf   t1con      ;alternative load
   goto   circle
   goto    clock
Any Ideas?
Offline croberts
Re: problem with MPLAB Assembler
« Reply #1 on: February 10, 2013, 10:53:33 pm »
Hello RodH
Try moving the 'end' directive to the end of your code.
Offline kripton2035
« Reply #2 on: February 10, 2013, 10:54:19 pm »
Hello RodH
+1
Offline Mr Smiley
« Reply #3 on: February 10, 2013, 11:59:18 pm »
Anything to do with
ten
   wovwf   porta
what's wovwf ??
It's in all you calls.
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
