Author Topic: problem with reciving answer from sim800  (Read 1168 times)
Offline ُSTP.AsghariTopic starter
  • Country: ir
« on: January 17, 2024, 02:31:51 pm »
When I give the AT command to the module. The module should give me the answer AT\r\nOK\r\n but to my surprise it gives the answer AT\r\r\nOOK\r\n. I understood this problem by getting the answer from the code below. While if I delete the wrong lines from the code below, the module does not respond.
Send_AT();
    do
      buffer=get_char();
    }while(buffer!='A');
buffer=get_char();
if(buffer=='T')
                       buffer=get_char();
       if(buffer=='\r')
                             buffer=get_char();
                             if(buffer=='\r')
                                      buffer=get_char();
                                      if(buffer=='\n')
                                                  buffer=get_char();
                                                   if(buffer=='O')
        if(buffer=='O')
        buffer=get_char();
        if(buffer=='K')
        buffer=get_char();
        if(buffer=='\r')
        buffer=get_char();
        if(buffer=='\n')
        for(i=0;i<5;i++)
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_13,GPIO_PIN_SET);
        HAL_Delay(500);
        HAL_GPIO_WritePin(GPIOC,GPIO_PIN_13,GPIO_PIN_RESET);
        HAL_Delay(500);
Offline Scrts
  • Country: lt
Re: problem with reciving answer from sim800
« Reply #1 on: January 17, 2024, 05:06:41 pm »
What do you see as a response when you hook up USB-UART adapter to your PC? Your code seems to be messy. Receive the full command from the module to the buffer and then parse the data.
Offline bookaboo
  • Country: ie
« Reply #2 on: January 17, 2024, 07:11:36 pm »
You need to forget the Simcom module for a while. Sharpen your embedded skills first
IoT modules are a world of pain, even if you have embedded experience.
Write, or find, a proper uart receive handler function.
Test it with an FTDI cable, or even loop a uart tx back from your processor.
