Author Topic: Problem with the circuit?  (Read 2025 times)
Offline Gowda1Topic starter
  • Country: in
« on: March 07, 2021, 09:05:01 pm »
Hello,
Could anyone please tell me what is the problem in the following circuit? Thank you.
« Last Edit: March 08, 2021, 09:16:54 pm by Gowda1 »
Online Ian.M
Re: Problem with the circuit?
« Reply #1 on: March 07, 2021, 09:16:18 pm »
There's nothing *wrong* with it, its just missing some fairly important stuff, and is *STUPID* unless LED1 has Vf>4V or min. If for acceptable brightness >25mA!  >:D
  • Country: in
« Reply #2 on: March 08, 2021, 08:24:06 pm »
Thank you for your answer. I mean what could be a problem with that?
Online Ian.M
« Reply #3 on: March 08, 2021, 08:35:05 pm »
Well you've just deleted the circuit diagram, so I'm working from memory.
If you want it to be buildable, specify component values.
If the LEDs power requirements are significantly under the limits I suggested, why not power it direct from the ATtiny I/O pin (with an appropriate series resistor)?
N.B. No-one here is likely to provide full solutions for anything that appears to be a student exercise.  You have to do the course work for yourself to learn the skills you will need once qualified and employed.  No-one wants to work with colleagues who have the paper certificate but don't have the knowledge or ability to do the job.  If you are *NOT* a student undertaking a formal course of instruction, and didn't take it down because you needed to remove it before your lecturer saw it or your college's anti-plagiarism software picked it up.  However, in general we are quite happy to guide you towards solving it for yourself, or even check your answers if you don't conceal the fact its a student exercise.  I apologize in advance for assuming you are a student, but only *IF* you can provide any evidence of your non-student status!
« Last Edit: March 08, 2021, 08:37:24 pm by Ian.M »
Offline oliviasmithh900
« Reply #4 on: March 08, 2021, 10:51:20 pm »
Where's the circuit ???  |O
Offline JohnnyMalaria
    • Enlighten Scientific LLC
« Reply #5 on: March 08, 2021, 11:15:36 pm »
Hello,
There are no components, connections, anything.  :-BROKE
Online Ian.M
« Reply #6 on: March 08, 2021, 11:18:38 pm »
IIRC it was an ATtiny 10, with a +5V supply and a pullup resistor on /Reset, with PB0 driving the gate of a BSS123 N-MOSFET, with a LED + series resistor between its drain and +12V.  No other components or component values were shown.
