Author Topic: Program stuck with simple math operations.  (Read 10461 times)
Offline zdelarosa00Topic starter
  • Country: mx
  • Manipulate your machine, you're a Technomancer...
« on: October 09, 2017, 02:11:25 am »
uC: dsPIC33FJ12GP202
IDE and Libraries: mikroC Pro for dsPIC
Simulator: Proteus ISIS
Compiler ver.: 6.2
So I have a question. I'm developing some code that communicates by UART (with library) with the computer in order to move a stepper
motor with precision, so by starting the program it asks for 1.-Direction (Left/Right). 2.-Degrees(0-360). 3.-Speed(0-120rpm max).
And by this point everything works, I managed to configure everything, dave the data and get the code structure in order, but
I have one issue..
When the UART finishes receiving the correct data, it calls a function in order to manipulate the data it got, and move the stepper motor the way
its desired. but the code stops running in the simulation just after the data is received, and the pins that correspond to the stepper motor never
change state, (said motor is conected throught a L298N H-Bridge controller).
Now, I have used that motor driver and said logic before, so first, as I didn't have experience with C fuctions, I made another
version of the program that gets rid of the function for troubleshooting and after doing that I reduced the problem to this secion of code:
//"Problematic section"------------------------------
    count=(grad/degperstep); //Establecer grados->cuentas (cuantos pasos vamos a avanzar)
    pos=0; //Conteo de excitación
    vueltaspseg=veloc/60; //Establecer rpm->us
    pasosporvuelta=stepperrev*vueltaspseg;
    time=((1/pasosporvuelta)*100)+1;
//End of section---------------------------------------
Note: Certain operations have what I consider an implicit trunk, like ones "int=float/int" or such, this for
getting those variables to take part in the variable delays in the for loop and such.
Now it's not inside a function, so calling and receiving the correct data was not the problem, now, when I try to debug inside mikroC,
it stops right in the first instruction of that block of code and gets to a routine so called "long2float" that never gets out of.
So, after trying to eliminate the need for calculations, I set the variables "count", "time", and "pos" to see if I have and output
and voilá, I have an output to the motor, so, my question is:
->Are those calculations too complex to do for the microcontroller or am I running out of memory? I can't very much understand what could be
causing the issue since this microcontrollers are supossed to have pretty strong RAM and math power.
Now this are my variables and the type they are:
//Variables--------------------------------------------------
const char right[]={0b1100,0b1100,0b0100,0b0110,0b0010,0b0011,0b0001,0b1001}; //Excitacion derecha
const char left[]={0b1001,0b0001,0b0011,0b0010,0b0110,0b0100,0b1100,0b1100}; //Excitacion izquierda
int pos; //Para controlar la posición de la excitación (1~8)
char salidas; //Pines PORTB para motor
int aa; //Para recibir de la UART
int grad, sent, veloc; //Peticiones de datos en enteros
float degperstep; //->
int stepperrev, count; //Para control de ángulo
float vueltaspseg; //->
float pasosporvuelta; //->
int time; //Para control de la velocidad
int xx; //Control de flujo de cuestiones/acciones
int i,j; //For statements
I haven't tried changing them all to one type (all float/all int) but that would really mess the process and I have change one or two (the ones that it uses
on the first line of calculations, for example)
so I doubt that really solves anything.
The following code is the moving routine and I have succesfully implemented it in the past for moving said motor:
//Start of the routine---------------------------------
if(sent==1) //Derecha
     for(i=0; i<count; i++)
      if(pos==8) {pos=0;}
      pos++;
      salidas=right[pos]; //Establecemos la posición de la excitación
      Hi(LATB)=salidas; //Movemos motor
      for(j=0; j<time; j++) {delay_us(1);} //Velocidad requerida
     }//Fin pasos
    }//Fin Derecha
    else //Izquierda
      if(pos==8) {pos=0;}
      pos++;
      salidas=left[pos]; //Establecemos la posición de la excitación
     }//Fin pasos
    }//Fin Izquierda
//End of move motor routine-----------------------------
I need the variable times and degrees for the cas when another motor with different specifications is used.
The compiler gives no errors and evreything works but the section I give.
How can I approach to solve this issue?, precision with variables is not a problem (I don't need 10 decimals in anything) but indeed
at least doing 45/1.8 and get a coherent result would be more than enough since it's the main goal of the program.
Space landfill waste consultants say: "If you think you can or if you think you can't you're right" - Always on my way to be a better electronic wizard
Online rstofer
Re: Program stuck with simple math operations.
« Reply #1 on: October 09, 2017, 02:44:20 am »
First of all, I would explicitly cast everything!
Second, I would make liberal use of printf() and send via UART all the intermediate and final results.
Third, I would create a dummy program to exercise just the math and casting.  Printf() everything.
Offline Nusa
« Reply #2 on: October 09, 2017, 02:57:26 am »
You're mixing floats and ints and making assumptions that the operation will be a floating operation, when in fact you may be getting some integer operations. No surprise you're getting unexpected results. Make everything explicit and you'll probably get better results. Also, your time equation could be simplified....the multiply is not necessary.
Offline sasa
  • Hobbyist in electronic
« Reply #3 on: October 09, 2017, 03:38:51 am »
As well, ensure possible division by zero is handled:
degperstep: count=(grad/degperstep)
pasosporvuelta: time=((1/pasosporvuelta)*100)+1;
Following will always return false result:
Instead:
time=((1.0/pasosporvuelta)*100)+1;
Common misunderstanding how implicit conversion works in C. There is no need to cast everything, just crucial parts in expression.
I will not going into correctness of time formula, however you can use integer arithmetic here avoding all implicit conversions. The whole critical section may look as follows:
if (degperstep!=0)
else
  count=0;
pos=0;
time = 6000 / (stepperrev*veloc) + 1;
« Last Edit: October 09, 2017, 03:53:35 am by sasa »
The 30+ years professional desktop software designer and software engineer
Offline NorthGuy
« Reply #4 on: October 09, 2017, 03:56:47 am »
"veloc" is integer. If it is ever less than 60, "vueltaspseg" will be zero, which will cause division by zero when calculating "time".
There's no need to mix floats and integers. Either do everything in floats, or, if it is too slow, do everything in integers. However, switching to integers will require more work, such as finding the correct scale etc.
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #5 on: October 09, 2017, 04:21:05 am »
when I try to debug inside mikroC, it stops right in the first instruction of that block of code and gets to a routine so called "long2float" that never gets out of.
So it locks up inside 'count=(grad/degperstep)'?
->Are those calculations too complex to do for the microcontroller or am I running out of memory? I can't very much understand what could be causing the issue since this microcontrollers are supossed to have pretty strong RAM and math power.
Floating point operations can take a lot of memory and CPU power. The dsPIC33FJ12GP202 is plenty powerful enough, but only has 12kB (8k Words) of ROM and 1kB RAM.
Try to use integers wherever practicable. When calculations involve fractional values, temporarily scale the numbers up until they become integers. To maintain accuracy do multiplications first and divisions last. For example if the step angle is 1.8º, do:-
  int decdegperstep = 18; // degrees per step * 10
  count = (grad*10)/decdegperstep;
Offline JPortici
« Reply #6 on: October 09, 2017, 05:04:57 am »
Please read both the programmer's manual (to understand the architecture and eventually how to write assembly routines) and the compiler manual, to see how to use the whole instruction set and eventually how to write assembly.
First thing, the dspic CAN perform a 32bit by 16 bit integer division with dedicated instructions in 19 clock cycles, but due to the nature of the algorythm it can't detect overflows. For this reason XC16 will perform a division by excecuting a software routine which can be many times slower ( i think it was in the order of 400 cycles) unless you tell the compiler to explicitely use the division instructions, by using a _builtin routine (but beware of the overflows, do it only when you are 100 percent certain that it won't overflow... for example if your divisor is a fixed number you can check if the divident is lower than X and in case use the hardware division)
I assume that MikroC is the same (I only used the dspic version with a 30f many years ago, so i don't know.)
Same thing if you want to use the 40bit dsp. it can operate with integers or fixed point numbers, but you have to understand how it works, where to place your variables in memory and such. 33FJ has a sligtly different implementation of the DSP than the 33EP so you should again check the programmer's manual and the compiler manual
third, in any case divisions take always a lot of time so unless you have the power or the time to crunch numbers, if you can do them elsewhere and either send the result or send a reciprocal and perform a multiplication instead (which takes one clock cycle for a 16x16bit multiplication).
fourth, as other said, don't mix floats with ints, and this MCU doesn't have hardware floating point and the conversion between the two always take time. you should keep using INTs or fixed point numbers
I don't think there's need to use floats, i'd just scale everything too (multiply by 10,20,60,100, ..) so they become integer numbers with sufficient accuracy
fifth and last as other said (but it's better to stress it out) you have many cases where you may be able to perform a division by zero, either by accident or by a result of calculations. you must add a check so that if any of the dividers is zero they are changed to something else, like 1. the behaviour of a division by zero is usually a math trap you have to address unless you want your MCU to reset
« Last Edit: October 09, 2017, 05:11:15 am by JPortici »
Online rstofer
« Reply #7 on: October 09, 2017, 02:56:47 pm »
Given that there is so little RAM, what is the possibility that the heap and stack are colliding?  It would be interesting to see the RAM map from the linker.  If there is no heap, what about the stack colliding with allocated RAM?
In addition to the other problems noted earlier.
Getting the wrong answer, even dividing by zero shouldn't cause the uC to halt.  But a stack collision will almost always result in something going seriously wrong.
Offline sasa
« Reply #8 on: October 09, 2017, 05:14:40 pm »
When division by zero is attempted, operation should be stopped and divide by zero trap should be generated.
« Last Edit: October 09, 2017, 05:19:16 pm by sasa »
Offline JPortici
« Reply #9 on: October 09, 2017, 07:17:52 pm »
as i said, a division by zero generates a math trap and sets the division by zero flag (Bit 6 of INTCON1).
I don't know how mikroC handles traps that don't have their explicit handler, but i would bet it either reset the MCU (and the debugger halts there) or it is stuck in a while(1) unless you write the routine
Online rstofer
« Reply #10 on: October 09, 2017, 08:08:20 pm »
Right, division by zero generates an arithmetic trap.  I have no idea where the trap vector branches nor what the handler code would do.  I wouldn't bet on 'hang' because that is just all wrong for an embedded system.  One bad sensor reading and the train goes off the track because the uC froze up.  I would hope that it would just deliver either a maximum result or zero but I wouldn't bet on it.
Or, maybe the user is suppose to write the trap code.  That would be a sensible choice.  But what to do?  The embedded system is supposed to keep running so just return zero and leave it up to the user to check the flags?
It is better to avoid dividing by zero in the first place.  Even then, what to do about a zero divisor?  Something else is wrong.
Check the documentation!
Offline sasa
« Reply #11 on: October 09, 2017, 09:04:47 pm »
There is nothing to speculate about, everything is explained by Microchip:
http://ww1.microchip.com/downloads/en/DeviceDoc/70189C.pdf
  • Country: mx
« Reply #12 on: October 10, 2017, 01:12:36 am »
I'm sorry, there's a couple things i'm not familiar with and almost sound like they're all software... What's the concept of 'casting' everything?... Also I'm using the UARTx library from the mikroC compiler and there's no such function as 'printf()', there's either
UART1_Write(); //Wich to my understanding sends an unformatted byte, and...
UART1_Write_Text("Wich sends a string");
 \$\Omega\$
  • Country: mx
« Reply #13 on: October 10, 2017, 01:16:24 am »
You're right, I didn't think of doing everything in floats, but for example there's a little routine where a for loop goes on a count of every step excitation that the motor has to do, what when the loop 'i' variable compares "i<56.789" for example? Does that affect the process of the loop of the compiler will try?, technically there could be a case where 'i' reaches from 56 to 57 and would be "i<56.786=FALSE", but that's just human thinking, I'm not sure how the compiler handles this kind of stuff (plus on the top of my head, 'i' is an integer here, wich could be more implicit conversions(?)) :-/O.
  • Country: mx
« Reply #14 on: October 10, 2017, 01:22:01 am »
Well, you've got a good point, with the divide by zero, but my 'degperstep' variable is a constant for when manipulating another types of motors, wich you change and compile before you use, mine just happens to be the classic 1.8º/step, wich I'm sorry I'm not sure I included in my original post, so I think that could be omitted...
Now, the part with the time formula seems interesting, I think I can actually make a "time=(100/pasosporvuelta)+1;" to loose some steps, also, that eventually ends up as a uS count in a delay so I thought I had it covered against zero with the "+1" part, since I can only use either 'delay_ms' or 'delay_us' so I came up with something that covers the minimum time cases wich aren't even 1mS between steps. :-/O
  • Country: mx
« Reply #15 on: October 10, 2017, 01:24:38 am »
Thanks!, I didn't know such thing!... Those implicit conversions where the ones I have so much doubt about, now.. How safe is everything floats?, as in a compare variable for the for loops, for example?, I don't find this compiler to be very good at troubleshooting freezes...
Online rstofer
« Reply #16 on: October 10, 2017, 01:25:39 am »
Suppose 'i' and 'j' are integers and 'x' is a float and I want an integer result:
i = (int) ((float) j / x));
'j will be converted to a float and divided by 'x' which is already a float.  The result will be converted to an integer and stored in 'i'.
 \$\Omega\$
There are probably functions that convert a numeric value (integer or float) to a string.  In C, itoa() converts an integer to an ascii string.  Similarly, ftoa() converts a float to a string.  Google for them.  Just do the conversion into a character buffer (array of chars) and use UART1_Write_Text(mystring) to print the results.  Make sure the buffer is long enough.
Different libraries implement these functions in slightly different ways.  Check your documentation.
« Last Edit: October 10, 2017, 01:43:20 am by rstofer »
  • Country: mx
« Reply #17 on: October 10, 2017, 01:27:34 am »
Yes, in simulation, apparently phisically, and inside debugging (doesn't stop but enters an assembler loop)...
That integer trick really seems to have sense... Am I really into danger of running out of memory with those operations?, I'm not sure if this IDE has some device estimation beyond what my code takes in kB.
  • Country: mx
« Reply #18 on: October 10, 2017, 01:41:04 am »
No need for checking the math architecture right now, also don't have that much time, I will try and use the scaled floats, and double check my math... I think its clear the uC can handle it so it's obviously down to my code... Thanks
  • Country: mx
« Reply #19 on: October 10, 2017, 01:43:22 am »
How serious?... I think this compiler takes for granted a lot of things, so memory is taking part in this discussion... But I do think is down to my code... I can't do much  better on doing the calculations before, but I can save a little instructions... Also, how wrong can that collisions go?, it's definatelly freezing but it's working just fine still... So I think it's healthy  :-DMM
  • Country: mx
« Reply #20 on: October 10, 2017, 01:45:05 am »
The debugger doesn't halt here, I'm not sure if I'm being explicit enough but the uC is the one who just stops responding in the UART comm, the debuger helps not much here since when it goes to that line it enters an assembler routine and just loops the crap out of it for who knows how long..
  • Country: mx
« Reply #21 on: October 10, 2017, 01:47:22 am »
Sure, I'm not polished enough in this compiler... But I'm sorry everyone is touching in that topic now... As far as the variable quantities go here... None of those return zero... At least the only one who implicitly does is the one who does 'int=int/float' where the second int can be smaller than the float...
  • Country: mx
« Reply #22 on: October 10, 2017, 01:49:14 am »
I had my share with interrupt knowledge, I think in this case is better to fix the code for avoiding the trap than to elaborate on the solution for the given trap
  • Country: mx
« Reply #23 on: October 10, 2017, 01:51:53 am »
Hi... Yeah.. .I'm past that issue already, thanks... I checked the documentation and am using a function now that is called 'atoi' wich does char->int, but guess what? It's stuck there now just after the UART reading that gets said char in the first place...
  • Country: mx
« Reply #24 on: October 10, 2017, 01:57:51 am »
Hey everyone, the first thing I did was to get rid of the variable procedures so a scene where only one motor is used it's now my code... (constant degrees per step and such)... I attach said code here:
This is the whole code now... (Wich still has a couple implicit nasty crap since I just read you're responses):
Wich now gets stuck in the 'atoi' func.
//--CONTROLADORA DE STEPPER PRECISA--
//1.-Grados?
//2.-Sentido?
//3.-Velocidad?
#include <built_in.h>
NOTAS APRENDIDAS:
/No se permite compilar un retardo variable....
/"delay_us(time)" -> wrong
/Las interrupciones pueden llamarse como absolutamente se quiera mientras
tenga la denominacion IVT correcta (tabla de vectores de interrupcion)
//Variables
char aa; //Para recibir de la UART
char grad, sentt, veloc; //Peticiones de datos en char
int gra,sent,velo; //Enteros
//Métodos
void movermotor();
//INICIO
void main()
//Configuración->
//SISTEMA
W15=0x0900;    //Pila acomodada
//MÓDULOS
UART1_Init(19200); //Init&Config de la UART, 8b data, no parity, 1 stop
delay_ms(100); //Delay recomendado
//TRISB.RB2=1; //Entrada RX
RPINR18=0x05; //RP5RX, pin 14
RPOR3=0b00011; //RP6TX, pin 15
//PINES
TRISB.RB8=0;
TRISB.RB9=0;
TRISB.RB10=0;
TRISB.RB11=0; //Salidas motor
//Inicializaciones
//stepperrev=648; //<-Pasos por vuelta del motor usado.....
//648
//degperstep=360/stepperrev; //Grados por paso del motor usado....
//1.8
xx=0;//Controla el flujo de preguntas
UART1_Write_Text("\n¿Cuántos grados desea girar?... (0~360°) \n");
UART1_Read(); //Limpiar para no recibir por equivocacion
//Código
while(1)
  if (UART1_Data_Ready())
    delay_ms(100);
    aa=UART1_Read(); //Recibimos dato
    switch(xx) //Flujo de preguntas
        case 0: //grados
          grad=aa;
          gra=atoi(grad);
          xx++; //xx=1;
          UART1_Write_Text("¿En qué sentido desea girar?... (1-Derecha, 2-Izquierda) ");
          break;
        case 1: //sentido
          sentt=aa;
          sent=atoi(sentt);
          xx++; //xx=2;
          UART1_Write_Text("¿A qué velocidad desea girar?... (uS) "); //(0~120 RPM)
          break;
        case 2: //veloc
          veloc=aa;
          velo=atoi(veloc);
          movermotor();
          xx=0;
          break;
        }//fin switch
   }//End dato recibido
  }//End while
}//End main
void movermotor()
    //Operaciones
    //count=grad/degperstep; //Establecer grados->cuentas (cuantos pasos vamos a avanzar)
    count=grad/1.8;
    //vueltaspseg=veloc/60; //Establecer rpm->us
    //pasosporvuelta=stepperrev*vueltaspseg;
    //pasosporvuelta=200*vueltaspseg;
    //time=((1/pasosporvuelta)*100)+1;
    time=veloc;
     //Acknowledgement
     UART1_Write_Text("Moviendo motor...");
     delay_ms(600);
     UART1_Read();//Limpiar
     UART1_Write_Text("Derecha... ");
      if(pos==8) {pos=0;}
      pos++;
     }//Fin pasos
    }//Fin Derecha
    if(sent==2) //Izquierda
     UART1_Write_Text("Izquierda... ");
      if(pos==8) {pos=0;}
      pos++;
     }//Fin pasos
    }//Fin Izquierda
    delay_ms(500);
    return;
}//Fin movermotor()
/*--INFORMACIÓN DE CÁLCULOS--------------------------------------
/>PASOS:---------------------------------------------------------
/Ej.: Si stepper tiene 648 pasos por revolución, 648 pasos=360°
/tiene 1.8° por paso (360/648), al pedir grados, dividimos
/entre la resolución del motor (Ej.: 45/1.8=25) (x/degperstep) y
/resultará el número de pasos: 25................................
/cuenta=(grad/degperstep)    ------------------------------------
/>TIEMPO:--------------------------------------------------------
/-La velocidad máxima son 120 RPM, (120/60=2)(vueltaspseg=vel/60)
/eso es 2 vueltas por segundo, a 648 pasos por vuelta son 1248
/pasos, (pasosporvuelta=stepperrev*vueltaspseg), en 1 segundo son
/entonces: (1/pasosporvuelta=801.28uS)(time=1/pasosporvuelta),
/time está en uS para la velocidad más alta.-------------------->
/>>SUMARIO:
/1.- vueltaspseg=vel/60 (FLOAT)
/2.- pasosporvuelta=stepperrev*vueltaspseg (FLOAT)
/3.- time=(1/pasosporvuelta*100)*100 (INT)
/Ej: 3 RPM->
/vueltaspseg=3/60 -> .05
/pasosporvuelta=648*.05 -> 32.4
/time=1/32.4 -> .03086*100 -> 30.86 -> 30 (en mS int, truncado)
/Ej. Final:
/delay_us(30); //3 RPM
/delay_us(801280); //120 RPM (vel máx)
