Author Topic: Programing a C8051F380  (Read 24348 times)
Offline ZoszkoTopic starter
  • Country: hu
    • ZoszkoWorks
« on: January 17, 2015, 02:01:56 am »
 I have just recieved a board with a Silicon Labs C8051F380 on it. It has something like a JTAG interface. I have got some sample .hex files for it as well. My only problem is I have got no idea how to program this. Please give me an ideo what is the cheapest way to get started with this. (Building something is definitely an option.) I have found the "owSilProg: AVR-alternative to Silabs toolstick" but those drones does not seem to use the F38X series...
BTW this question was off-topic for the dear "StackExchange" users as "Questions seeking recommendations for specific products or places to purchase them are off-topic as they are rarely useful to others and quickly obsolete. Instead, describe your situation and the specific problem you're trying to solve."
I hope you can help me programimng my new board. I have got a bootloader.hex so as we manage to get that on this MCU i can use the onboard USB or standard serial cable to program it from the Silabs IDE.
Thank you for tanking Your time and reading this!
Z
« Last Edit: January 17, 2015, 02:51:27 am by Zoszko »
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
Re: Programing a C8051F380
« Reply #1 on: January 17, 2015, 09:25:45 pm »
You don't program that, it is ancient.
But if you insist you can use this thing perhaps. http://nl.farnell.com/silicon-laboratories/debugadptr1-usb/adapter-usb-debug-for-c8051fxxx/dp/1186943
Then you can use Keil uVision or Tasking to get some C running in the thing.
Offline wraper
  • Country: lv
« Reply #2 on: January 17, 2015, 10:16:32 pm »
It is not ancient and actually quiet powerful.
Offline free_electron
    • SiliconValleyGarage
« Reply #3 on: January 18, 2015, 12:22:13 am »
it's not ancient. the silabs processors are really good ! they got one that can run off 0.9 volts !
you need to buy the silabs programming dongle. no way around it.
Offline digsys
    • DIGSYS
« Reply #4 on: January 18, 2015, 11:12:32 am »
I'm with FreeE ! The Silabs implementation of the 8051, with all it's analogue / digital on-board is awesome. I've made several DOZEN projects with
it so far, and intend to do many more. The F380 is in FACT a NEW USB version - https://www.silabs.com/products/mcu/usb/Pages/default.aspx
I've used other USB types before. DON'T buy the debugger as a stand-alone, a MUCH better value option is to buy one of the VERY cheap dev kits -
https://www.silabs.com/products/mcu/Pages/DevelopmentTools.aspx
https://www.silabs.com/products/mcu/Pages/mcu-development-kits.aspx
You not only get the USB / Jtag interface, but a fully working dev board, software and other goodies (depending on the kit), usually for the same
price as others sell just the dongle. You don't need to get the dev board for your specific MPU type either !!
I've bought over a dozen different types to date, so I do know about them.
A year or so ago, after many of us complained about Kiels high prices, they made their base dev software FREE, and you can do quite a lot with it.
Offline dannyf
« Reply #5 on: January 18, 2015, 11:39:13 am »
Or just go to ebay and you find those programmers less than $20.
it is ancient.
Anything but.
I am a big fan of 350. Great chip.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #6 on: January 18, 2015, 02:19:00 pm »
They do have fancy analogs ones. This one doesn't, and it is based on 8051 which can be considered legacy. (1980's)
However, due to it running on an 8051 they do not have USB or CAN peripherals, but instead they have coprocessors with some interface registers. Which offloads a lot of the protocol handling.
(do not have an interrupt while writing to those register btw, it'll corrupt your data)
But I'm a young engineer, who learned only the recent stuff. Which makes the traditional stuff look like antiques. Sorry.
Offline wraper
  • Country: lv
« Reply #7 on: January 18, 2015, 02:41:01 pm »
LOL what? It has USB and 500ksps 10 bit ADC. 48 MIPS
Offline wraper
  • Country: lv
« Reply #8 on: January 18, 2015, 02:45:37 pm »
about 8051 "legacy":
The CIP-51 employs a pipelined architecture that greatly increases its instruction throughput over the standard 8051 architecture. In a standard 8051, all instructions except for MUL and DIV take 12 or 24 system clock cycles to execute with a maximum system clock of 12-to-24 MHz. By contrast, the CIP-51 core executes 70% of its instructions in one or two system clock cycles, with only four instructions taking more than four system clock cycles and has a maximum system clock of 100 MHz. The CIP-51 has a total of 109 instructions
Offline dannyf
« Reply #9 on: January 18, 2015, 06:05:01 pm »
Those silab stuff is anything but "traditional". Read a datasheet and you may be able to appreciate them.
Offline Yansi
« Reply #10 on: January 18, 2015, 06:31:08 pm »
At least some level of knowledge of old computer and microcontroller systems is I think the essential of every EE.  8051 core may be "antique", but still used in very wide range of applications today with a lot of modifications and variants, like Atmel's single cycle or 6 cycle per instruction cores, or these relatively powerfull micros from Silabs or Cypress. The x51 core is very often used as a standard building block in many new designs, including some top-level stuff from companies like TI. Lastly I saw x51 core in their USB/UART bridges and so on. This core is easy to implement, and every good EE should know how to use it, regardless how antique it might look.
Offline digsys
    • DIGSYS
« Reply #11 on: January 18, 2015, 10:09:04 pm »
Quote from: Jeroen3
However, due to it running on an 8051 they do not have USB or CAN peripherals, but instead they have coprocessors with some interface registers. Which offloads a lot of the protocol handling.  (do not have an interrupt while writing to those register btw, it'll corrupt your data)
That's funny, I use both CAN and USB fine, and never had data corruption. Maybe one day when you grow a bit more hair, you'll learn how too :-)
Quote from: Jeroen3
Good luck with that.
The following users thanked this post: TheNewLab
Offline amyk
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #13 on: January 19, 2015, 07:18:31 am »
We've got one of their C8051F04's (with fancy adc) in a product where development stated >5 years ago.
While upgrading and fixing bugs nobody had looked at before it turns out most of these bugs are in the hardware. Randomly corrupting sfrpage registers, corrupt can data, missing adc cycles. And now when devices are becoming networked, the demand to upgrade existing stuff is really pushing the envelope on these "antique" cores.
Sorry for pushing it off-topic. But in my opinion there is better stuff around to get started with.
The curse of being ee is that there is always something better...
A little advice on using those silabs usb jtag devices. They do not like relays. If you have a (din-rail) relay near, it'll crash the debugger. It's an issue we're having since the beginning.
« Last Edit: January 19, 2015, 07:20:47 am by Jeroen3 »
Offline JoeN
  • We Buy Trannies By The Truckload
« Reply #14 on: January 19, 2015, 12:22:24 pm »
This is correct.  I got a few of these microcontrollers as samples and this programmer works well with Keil as a cheap solution.  Keil is limited to a few K but if you can get it up and working then you can start worrying about exceeding code size limits or not.
Have You Been Triggered Today?
Offline digsys
    • DIGSYS
« Reply #15 on: January 19, 2015, 01:01:46 pm »
I don't normally continue with these type "debates", but you make some pretty ridiculous claims ...
Quote from: Jeroen3
.. one of their C8051F04's (with fancy adc) ... it turns out most of these bugs are in the hardware. Randomly corrupting sfrpage registers, corrupt can data, missing adc cycles.
I write my own kernels, and code exclusively in assembler. Then I run trace points on DSOs and monitor memory/IRQs/processing times.
To date, after 35+ yrs, I have rarely had any products exhibit the problems you have, including the Silabs range from their origins.
Maybe you (or your programmers) should learn to program better and not rely on free C-compilers. Heck, even expensive C-compilers aren't perfect.
And that goes for ANY MPUs free/otherwise C-compiler. YES, they have a LOT of internal hardware and a "smart" programmer would know how to
keep that in mind and work with it.
Bottom line - If user1 has NO issues and user2 does have issues, well .. work it out. Don't trash cores just because you can't get it to work, it's
not very professional. And YES, the free Keil compilers do have "bugs".
Quote from: Jeroen3
  ..... pushing the envelope on these "antique" cores.
Nothing wrong with the cores. Learn assembler IF you want to PUSH the MPU. Same with ANY MPU. That's supposedly your job to figure out.
Quote from: Jeroen3
  ... there is always something better...
What the HECK does "better" mean. You chose an MPU for a job. Should I use a P7 cause it's better?? That's just a plain dumb statement. Sorry.
Quote from: Jeroen3
  ... They do not like relays. If you have a (din-rail) relay near, it'll crash the debugger ....
A lot of dev systems don't like arcing relays, or bad earths or noise or .. or .. YES, I can get the debugger to crash, as I could with ANY of my dozen
or so $10K - $20K emulators / dev systems. YES, some were more robust, but I paid a shltload for them. On some projects where I do get a few
more crashes than I'd like, I put better filtering / grounding .. a bit of rewiring and all is acceptable again. Again, that's "our" job to figure out.
All yours.
Offline dannyf
« Reply #16 on: January 19, 2015, 01:06:41 pm »
corrupt can data
How can they have corrupt CAN data when you didn't think they have CAN?
Offline dannyf
« Reply #17 on: January 19, 2015, 01:20:44 pm »
Programmers are $20 or less on ebay.
Offline amyk
« Reply #18 on: January 19, 2015, 03:19:44 pm »
Yes, the bugs are in the hardware - the hardware around the MCU. If you don't have enough decoupling or your power supply is noisy, you'll get symptoms like that.
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #19 on: January 19, 2015, 07:51:18 pm »
This debate is endless. I give up.   |O
I was wrong the first post, the chip isn't ancient. It is just legacy compatible.
Not a problem. Windows is too. The 8051 part just makes it look really old.
We've apparently used a bad version, a bad (expensive) compiler and a bad initial software architecture. (not my fault :))
Now I'm chasing bugs that happen due to hardware.
There are no power supply problems, the analogs in the product are flawless, and it passed rf and conducted emc tests. Impossible with bad power supply. The debugger is maybe improperly decoupled. It's annoying. Not more that that.
You don't need the debugger for compliance testing. Do you?
The debugger came with the dev board in the box. I'm not surprised if they still do.
Offline dannyf
« Reply #20 on: January 19, 2015, 08:32:59 pm »
Satirizing your own mistakes doesn't make them any less mistaken. You were wrong because of your content being wrong, nothing else.
The right thing to do is to man up and learn from your mistakes so you don't make them next time.
Offline MarkL
« Reply #21 on: January 19, 2015, 08:53:51 pm »
http://www.silabs.com/Support%20Documents/TechnicalDocs/AN127.pdf
http://www.silabs.com/Support%20Documents/TechnicalDocs/C2spec.pdf
The ISP protocol is not that much more complex than what you'd find on an AVR or PIC. They even provide sample code for using one of their own MCUs as a programmer.
If you have a beaglebone or other linux dev board laying around, there's also an experimental kernel driver that implements the C2 protocol (called "c2port").  It's a bit-bang implementation and is there to allow programming of co-resident SiLabs processors.
It works fine but you need to make a new kernel since it's not made by default.
Offline westfw
« Reply #22 on: January 20, 2015, 12:55:28 am »
[don't] rely on free C-compilers.
One problem with these "legacy architectures" is that no matter how you speed them up or add memory, it's still not going to be "C friendly", which makes the compilers more complex, prone to errors, and/or expensive and special-cased.  (Although, Silicon Labs now gives away a free full version of Keil's compiler, which has a pretty good reputation...)
Offline Bassman59
  • Yes, I do this for a living
« Reply #23 on: January 20, 2015, 05:39:43 pm »
Funny, we've been using various SiLabs 8051s for a dozen years, and we've never had any issues like you're allegedly seeing. And this is across the whole range of their parts, from the old F005 and F006 through the F120 (quite the workhorse for us) to the F580 and the newish F850s. They get a lot of use in housekeeping applications, so the ADC gets lots of use. They all work as advertised. What sort of debugging did you do? Sounds like you had power-supply issues.
We did note that if you overrange the ADC inputs on the F005, the chip dies.
Offline ebclr
