Consider the PSOC ARM families, PSOC 4 and 5LP and very soon PSOC 6.
You get (part dependent, 5LP family all of th below)
1) ARM Core, M0 or M3, in case of POSOC 6 dual core M4 & M0
2) DSP engine, filter wizard
3) UDB blocks, create custom components via schematic capture or verilog or UDB editor
4) 20 bit DelSig and / or 12 but SAR A/Ds
5) Onboard reference
6) Free tools
7) Boards ranging from $ 10, $ 25, and others, all with debug/program via USB, some with arduino footprint
Video training library robust, forums very active
9) See attached component library, drag and drop onto schematic, route to pins or internal. See attached.
Components are onchip resources. Complete with code to do simple C calls to manipulate.
10) Start at the very basics and learn capability as you go
11) Lots of analog, OpAmps, Mixer, VDACs, IDACs, TIA, Comparator.
12) Tons of example code right in tool, can use to learn or as basis for a new project
Regards, Dana.
