Author Topic: programming atsam3s2c  (Read 1968 times)
Offline nourTopic starter
  • Country: sa
  • calm down, it is just a smoked oPamP!
« on: February 25, 2016, 08:54:28 am »
I used to use USBasp to program avr microcontrollers from atmel
now I have ATSAM3S2C-AU from atmel and I want to program it what hardware should I use
I hope if possible that there is something that I can made out of my box
lets just begin what programmer I need to use and after that see if I can build it my self or not
thanks
if what I have wrote doesn't make sense for you or you think there is something wrong, please correct me, I am still beginner and what I know probably less than what you know
Offline 97hilfel
Re: programming atsam3s2c
« Reply #1 on: February 25, 2016, 01:47:56 pm »
I'm currently working with a AtSAMD20J18 and need to use a Atmel ICE, maybe you can find a cheaper ARM debugger but as cheaper option you could use a Xplained Pro board It connects via SWD to yout controller
Gesendet von iPhone mit Tapatalk
  • Country: sa
« Reply #2 on: February 25, 2016, 01:58:41 pm »
I forgot to mention that this microcontroller from the same family used in arduino due
I wonder if I can use the same way for programming my ATSAM3s like the have done in arduino due
still no experience ;D
« Last Edit: February 25, 2016, 02:07:03 pm by nour »
