Author Topic: programming over SPI with multiple devices  (Read 2266 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: October 14, 2015, 07:57:24 am »
I'm going to put an SPI device (ADC) in my system along side my AVR, but my AVR is programmed by SPI, presumably because my ADC needs enabling on the enable pin before it does anything there will be no conflict as the chip will just go high impedance when the AVR is put into programming mode and stops talking to it
Offline Mr.B
Re: programming over SPI with multiple devices
« Reply #1 on: October 14, 2015, 08:09:55 am »
I have done this before and not had any problems with it.
The "other device" had a pull-up resistor on the CE to ensure it was not enabled while the AVR powered up.
Offline mikerj
« Reply #2 on: October 14, 2015, 10:41:14 am »
You should provide a suitable pull-up resistor on the chip select lines of any SPI slave devices, but provided this is in place there should be no problem.
  • Global Moderator
« Reply #3 on: October 14, 2015, 11:58:31 am »
I'l put a 10K pullup and I've found a free pin to act as the CS line phew how long ago did i start designing this thing ?
