Author Topic: PSA: Wiznet chip is not a real networking stack  (Read 9626 times)
Offline tellurium
  • Country: ua
Re: PSA: Wiznet chip is not a real networking stack
« Reply #75 on: October 11, 2026, 02:45:40 am »
Has anyone tried the Mongoose network library?
Yes, I tried it
Open source embedded network library https://mongoose.ws
TCP/IP stack + TLS1.3 + HTTP/WebSocket/MQTT in a single file
Offline Dan N
« Reply #76 on: October 11, 2026, 12:52:30 pm »
I've been trying out Mongoose on a W6100-Pico2 eval board (porting W5500 raw driver was trivial).  The code is a few 10kB bigger compared to using the builtin sockets but part of that is full implementation vs partial/toy of the Wiznet example code.  The overall package seems to be a good fit for the home automation things I'm doing.
The following users thanked this post: tellurium
Offline tellurium
  • Country: ua
« Reply #77 on: October 11, 2026, 02:57:33 pm »
Wiznet created W55RP20 SIP which is a combo W5500 + RP2040 + flash.
Could be handy for those sort of things, they also have a devboard for that https://wiznet.io/products/evaluation-boards/w55rp20-evb-pico
Would be nice if Wiznet created a cut-down W5500 variant without TCP/IP stack, just an Ethernet transciever, I bet it might be cheaper than W5500.
Online uer166
« Reply #78 on: October 11, 2026, 10:51:24 pm »
What is the use case of a Wiznet without a TCP/IP stack? If you're gonna implement it in software, it's much cleaner to just use an MCU with an Ethernet peripheral + PHY over RMII rather than hack it together over SPI bus.
Offline gerbay
  • Country: tr
« Reply #79 on: October 11, 2026, 11:01:59 pm »
Wiznet created W55RP20 SIP whicWould be nice if Wiznet created a cut-down W5500 variant without TCP/IP stack, just an Ethernet transciever, I bet it might be cheaper than W5500.
I suppose it would be good for ATmega and PIC users, but Microchip and WCH already have solutions like this—and WCH's prices are very reasonable.
Offline tellurium
  • Country: ua
« Reply #80 on: October 12, 2026, 08:03:20 am »
Do they? I was not aware of it.
I know that WCH and Microchip and TI have micros with built-in MAC and PHY.
I am not aware of anyone offering a standalone MAC+PHY with pure Ethernet send/receive and no extra stack.
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #81 on: October 12, 2026, 08:41:30 am »
CH390 - versions with SPI & Parallel interface. Includes MAC address
https://www.wch-ic.com/products/productsCenter/mcuInterface?categoryId=4&tName=Ethernet%20controller
Also CH392/394 with integrated stack
https://www.wch-ic.com/products/CH394.html?
« Last Edit: October 12, 2026, 09:02:50 am by mikeselectricstuff »
Day Job: Mostly LEDs
Offline westfw
« Reply #82 on: October 12, 2026, 08:50:30 am »
The Microchip ENC28J60 was a rather early (2006) 10MBit Ethernet Controller (with Phy.)
Talks to a microcontoller via SPI, available in DIP28 (!), and rather reasonably priced (~$5)
There is also the ENC424J600 (in 2009), which adds 100Mbps, more buffer memory, a parallel interace, and a "security engine."  But I don't think it has reached as far.  (Too little, too late?)
« Reply #83 on: October 12, 2026, 09:30:15 am »
KSZ8851 - paralell or SPI, 100M internal PHY, a bit expensive
https://www.microchip.com/en-us/product/ksz8851
Offline tellurium
  • Country: ua
« Reply #84 on: October 12, 2026, 11:43:07 am »
Yeah, price wise WCH CH390H is apparently the best, ~1.5 USD per unit
