Author Topic: Psoc 1  (Read 2130 times)
Offline R_G_B_Topic starter
Psoc 1
« on: May 29, 2020, 05:03:28 pm »
Hi, I liked using the psoc 4 and 5. Especially the psoc 4. I managed to get a cy3210 psoc 1 evaluation kit.
The psoc designer is not as easy to drive unlike the creator software.
However I thought having the psoc 1 with the 28 pin device is useful for some projects. Especially the 12 analogue blocks.
Now I'm starting to have second thoughts on using it. Unlike the psoc 5 and 4
If you want a clock you just drag and drop. The psoc 1 does things very differently very manual. I can not figure out how to configure a simple frequency divider or a clock using the 8 bit timer. I tried setting up a simple Manchester encoder using an ex or gate and a clock. I can get the random generator to work but then the 8 bit timer is a head ache to figure out. I get narrow pulses on the selected I/o pin but when I try to change the period, clocks etc it's still the same. Can any one who's used the psoc 1 help.
Is anyone  on this forum happy using the psoc 1 the analogue blocks such as the built in capacitive filters are handy to have.  I tried searching for forums on psoc 1. None existent?
I don't know why they did not include them on the psoc 4 and 5.
Thanks
R_G_B
Offline kripton2035
Re: Psoc 1
« Reply #1 on: May 29, 2020, 05:23:58 pm »
Offline ebclr
Re: Psoc 1
« Reply #2 on: May 29, 2020, 06:19:17 pm »
this channel is all about Psoc
https://www.youtube.com/channel/UCHj-2CF2CCzuQkT8cKMNuCg
You need some effort isn't  easy English
Online mjs
Re: Psoc 1
« Reply #3 on: May 30, 2020, 04:07:34 pm »
I did a few interesting projects years ago with them, but nowadays I'd go with 4 or 5 unless there would be a really compelling reason for using PSoC1. And even then I'd try to DSP with some other controller (including PSoC 4/5) first.
To get proficient with the PSoC analog blocks has a steep learning curve, but you can do wonders with them. A few examples I used were synchronous demodulation for tiny signals, filtered PRN generation for GNSS signal chain control, adaptive line frequency filtering for EEG signals.
Re: Psoc 1
« Reply #4 on: May 30, 2020, 07:22:59 pm »
I tried to use the psoc 1 again today I har given up. It is really a struggle to set up a basic clock using the timers.  So I went back to using the psoc 5. It does not have analogue filters but it has everything else.  The psocs  can be useful
for building lock in detectors demodulator circuits  good for analysing and discovery different circuit ideas especially good when used with the analogue discovery and it's instruments etc.  Very useful devices for prototyping. Theres also an analogue pioneer  kit.
R_G_B
Offline fmkit
  • Country: il
Re: Psoc 1
« Reply #5 on: May 30, 2020, 08:31:26 pm »
 I've learned about PSOC1 internals by watching changes done to PSoCConfigTBL.asm after pressing F6.
PSOC1  LASERTAG FPV, Laser RX  consist of 3 bias resistors, one photoresistor and  one ceramic cap
was able to hit targets 300m away
The following users thanked this post: R_G_B_
Re: Psoc 1
« Reply #6 on: May 31, 2020, 01:16:42 pm »
Clean and build the project fixed the problem.
Thanks
R_G_B
