Author Topic: PSoC combinational loop  (Read 2496 times)
Offline blueskullTopic starter
  • Country: cn
  • BA7LKP
« on: July 07, 2016, 06:32:11 pm »
Is there any way to create an async SR latch inside a PSoC 4 device? Its macro library contains clocked SR latch, but I need an async one.
I created one with combination logic elements, but it shows the following warning.
Does it mean it have already broken the net for me (which is not what I intended to do), or it tells me that I should break the loop, but I have the discretion?
Offline danadak
Re: PSoC combinational loop
« Reply #1 on: July 08, 2016, 02:27:12 pm »
I had a problem where optimization would take out gates I wanted to stay, no warnings.
That was with all optimization off, at the time, ~ 3 years ago, no way to resolve the issue.
I would post this on Cypress.com PSOC forum, there may be a way to
defeat warning and make sure no nets are broken or to force particular
net routing.
Of course you could always eat a pin or two and route so tool does not know you
have latch loop........create the "net" externally.
Regards, Dana.
Offline Tainer
« Reply #2 on: July 08, 2016, 05:06:29 pm »
You could try making your own implementation in verilog
