Author Topic: PSoC EMC  (Read 3011 times)
Offline luky315Topic starter
  • Country: at
PSoC EMC
« on: May 12, 2015, 02:06:35 pm »
Has anyone experiences with Cypress PSoC in demanding environments (Automotive, Electric Drives, Industrial)?
Are they more susceptible to external interferences then "traditional", non configurable microcontrollers?
Offline jboard146
Re: PSoC EMC
« Reply #1 on: May 12, 2015, 07:59:40 pm »
My understanding is that they are flash based so anything that would kill any other flash based device would PSoC as well. This is just my opinion and have ZERO facts to back this up.
What does Cypress say?
Offline miguelvp
Re: PSoC EMC
« Reply #2 on: May 13, 2015, 12:44:00 am »
For what I've seen from their product selector, only the PSoC 1 has Automotive qualified chips, that doesn't mean the other ones (3, 4, 5LP and 4BLE) are not present in cars, but I think they are in non critical applications.
Maybe this link helps:
http://www.cypress.com/?id=3
But I guess it depends what do you have in mind.
Use their support links, they are very quick and professional and they don't bite :)
Out of the links in this page, Open a case would probably give you the best response, but you need to register (for free) with them, downside registering is that if you look at any datasheet while signed in, they send you e-mails with a survey even if it's a pdf that you already got before.
http://www.cypress.com/?id=4
Also check their roadmaps:
http://www.cypress.com/?app=search&searchType=advanced&keyword=&rtID=491&id=0&applicationID=0&l=0
Offline T3sl4co1l
    • Seven Transistor Labs
Re: PSoC EMC
« Reply #3 on: May 13, 2015, 01:54:00 am »
Not familiar with them myself, but I can't imagine what would be a concern beyond the usual matters -- stable logic levels, solid supply voltage, keep ESD away, etc.  Analog parts will have the added restriction of ADC aliasing or RF rectification (bipolar op-amps being most sensitive to the latter, but PSoC stuff might exhibit some effects, too).  (And obviously, RF rectification from input protection diodes is always a concern for analog/precision, regardless of what it's going into.)
Seven Transistor Labs, LLC
  • Country: at
Re: PSoC EMC
« Reply #4 on: May 13, 2015, 05:18:00 am »
At the moment I'm using the Freescale Kinetis KEA with proven good EMC and ESD performance.
My question is targeted at (professional) PSoC users which (idealy) passed a EMC certification or something similar with a product containing a PSoC. The reason I ask this because I have had a bad experience in the EMV Lab with a Microcontroller from another manufacturer which was clearly related to the IC itself.
