Loading [MathJax]/extensions/Safe.js
Author Topic: Rasberry pi  (Read 7185 times)
Offline melrelTopic starter
Rasberry pi
« on: September 29, 2012, 04:37:41 am »
Hey guys.  Any advice on whether we jump into this let is pass for a while.  A load of schools in UK are using this in their media and IT courses.  Sounds great.  Any ideas? Guidance?  Thanks
Offline westfw
Re: Rasberry pi
« Reply #2 on: September 29, 2012, 08:21:08 am »
Quite a few threads here on raspberry pi.
However, this is one of the first I've seen that indicates that it's being used as originally intended (an educational tool.)
Good!
Offline mianchen
Re: Rasberry pi
« Reply #3 on: September 29, 2012, 09:24:50 am »
They are now even "Made in UK"... :)
Offline RCMR
Re: Rasberry pi
« Reply #4 on: September 30, 2012, 01:30:00 am »
Reminds me of the proud days of BMC  -- well I hope not  :o
Offline poptones
Re: Rasberry pi
« Reply #5 on: September 30, 2012, 01:35:33 am »
I just watched a Makerfair interview with eben something of the Pi folks and he said they're working with some new plant in China that will have nearly unlimited production capacity. Maybe some are made int e UK but it sounds like most will still come from China.
Offline nctnico
Re: Rasberry pi
« Reply #6 on: September 30, 2012, 11:40:00 am »
If there is no manual labour involved there is not much advantage of having a 'product' like the Raspberry pi assembled in China. Most of the production is a matter of turning an assembly line on and wait for the PCBs to come out of it.
Offline poptones
Re: Rasberry pi
« Reply #7 on: September 30, 2012, 07:58:54 pm »
You're assuming that a production line exists outside China that can handle 20,000 units a day.
Offline RCMR
Re: Rasberry pi
« Reply #8 on: September 30, 2012, 11:22:05 pm »
And forgetting the most important (and often most noticeably missing) link in the whole process...
Quality Control.
Some Chinese companies need to learn that QC involves more than just putting a little sticker on everything that falls off the end of the production line and is not so badly damaged that it won't still fit inside the box.
Offline EEMarc
Re: Rasberry pi
« Reply #9 on: October 01, 2012, 10:39:57 am »
You are right. My Pi needs to go back because of a soldering issue. From what I've heard, there are many more going back as well.
Re: Rasberry pi
« Reply #10 on: October 08, 2012, 07:49:05 pm »
interesting comments.  Thanks guys
Offline tom66
Re: Rasberry pi
« Reply #11 on: October 10, 2012, 02:49:07 pm »
The new Farnell ones are made in Pentcoed, Wales.
Offline Psi
Re: Rasberry pi
« Reply #12 on: October 11, 2012, 12:34:53 am »
This company in Austria will colocation your pi for free if you send it to them.
100MBit  100GB traffic
https://www.edis.at/en/server/colocation/austria/raspberrypi/
I cant see it lasting that long, they will be flooded with people wanting free hosting.
« Last Edit: October 11, 2012, 12:38:27 am by Psi »
Offline gxti
Re: Rasberry pi
« Reply #13 on: October 11, 2012, 07:59:50 pm »
It's also an incredibly stupid idea, from both sides. From what my friends who have one have said, it's barely stable enough to keep running on their desk, let alone across the pond in a "datacenter". And you can't even include storage other than a USB stick so its only real use is as a proxy. Might as well just lease a VPN or VM from a reputable company.
Offline Psi
Re: Rasberry pi
« Reply #14 on: October 11, 2012, 10:51:55 pm »
You can get 64GB usb sticks easy and ive seen 128 and 256GB on occasion.  So storage isnt too much of an issue.
But yeah, if they're unstable that would be a pretty big problem.
Send them two, one running your own custom firmware, only a few 100 lines of code needed to run the NIC and toggle a gpio when it gets a special TCP packet. Then connect that GPIO to your other pi on the reset line.
You could even add some code to enable you to reflash the usb stick remotely.
« Last Edit: October 11, 2012, 10:56:59 pm by Psi »
Offline poptones
Re: Rasberry pi
« Reply #15 on: October 11, 2012, 11:35:56 pm »
I can get a server at amazon that runs any software I want, has nearly infinate access to resources if I should need more, and which ocsts me virtually nothing to start out, not even the fifty bucks and six month wait for a pi.
It doesn't surprise me someone thought of offering this. From what I have seen so far, these things are useless as tits on a bull. But don't tell my customers...
Offline Psi
Re: Rasberry pi
« Reply #16 on: October 12, 2012, 03:05:26 am »
Maybe its a bit crap/unstable with the shipped OS containing lots of extra pi features but if you wipe that and install the ARM version of debian it should be pretty stable for a colo box.
