Author Topic: Reading Coretx M4 EEPROM  (Read 1795 times)
Offline ali_asadzadehTopic starter
« on: June 14, 2018, 10:17:37 am »
I have a MK10DX256LH7 device,It's from a 3rd party equipment, I have connected to my XELTEK 6100 programmer and was able to read the flash memory content, I want to know if it's possible to read the EEPROM with it too? or can I use J-link?  Since I can not find any info regarding reading the EEPROM content in neither j-link nor XELETEK program.
Any Ideas are welcome ;)
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Online wraper
  • Country: lv
Re: Reading Coretx M4 EEPROM
« Reply #1 on: June 14, 2018, 10:20:44 am »
Are you sure that both Flash and EEPROM content were not saved in a single file?
Online wraper
  • Country: lv
« Reply #2 on: June 14, 2018, 10:25:32 am »
I briefly read a datasheet and apparently there is no EEPROM to begin with, only EEPROM emulation actually using Flash memory.
« Reply #3 on: June 14, 2018, 10:26:25 am »
Thanks, I meant the 32KB flex Memory :)
Online wraper
  • Country: lv
« Reply #4 on: June 14, 2018, 10:30:37 am »
I'd assume it already should be in your dump file.
