Author Topic: Reading EEPROM data from PIC  (Read 30510 times)
Offline Alexei.PolkhanovTopic starter
« on: November 05, 2013, 04:34:20 am »
Nespresso C60 coffee maker died in our office. We got replacement and I decided to tear down old machine. (Phos are here if anyone is interested: https://plus.google.com/u/0/photos/+AlexeiPolkhanov/albums/5942601403050829121.
I really wanted to find out how many cups of coffee this machine made over its lifespan, so once I got to the controller board I started looking for EEPROM or something like that hoping that I may be able to get data from it. What I found is a PIC Microcontroller - PIC16F685 (Datasheet: http://ww1.microchip.com/downloads/en/DeviceDoc/41262A.pdf). It has EEPROM inside the chip itself.
Unfortunately I don't have any experience with PIC micros. I am wondering if it is possible to get data from internal EEPROM in this microcontroler? How would I do that?
I found this debugger http://www.microchipdirect.com/productsearch.aspx?Keywords=PG164130 ) and probably should get it anyway cuz I tend to bump into PICs a lot lately. I can definitely reprogram the chip if it is not fused and read the EEPROM programmaticaly just like datasheet say, but I would probably wipe off the EEPROM in a first attemp to re-programe the device?
Controller board has 5 unconnected through hole pads that I think maybe JTAG, but maybe not because Datasheet that I found does not even mention JTAG  :-\
Offline garak
Re: Reading EEPROM data from PIC
« Reply #1 on: November 05, 2013, 08:36:21 am »
Any halfway decent PIC programmer ought to be able to read the EEPROM data out of the PIC. I think even the cruddy parallel-port based stuff can do this.
However, this doesn't mean that the PIC will let you. I can't remember if the PIC16F685 has an EEPROM data protection function, but many many PICs do, and if it's turned on then you're scuppered. It's fairly common for manufacturers to switch on every protection feature they can find in a paranoid effort to protect their IP, regardless of if anyone would actually WANT to steal it.
At any rate, keep the PIC. The part number you gave is not an OTP version, so you can use it again in something else should you want to.
EDIT: This sentence, no verb... ::)
Offline amyk
« Reply #2 on: November 05, 2013, 09:07:00 am »
Most if not all PICs have code protection function. While it will be common that the protection is enabled, it's not 100% of the case so you should try anyway.
(And even if it is, it's not 100% effective...)
Offline garak
« Reply #3 on: November 05, 2013, 09:30:17 am »
OP was referring to the EEPROM rather than program code, and I don't think that they all have protection on that. I agree that it's definitely worth a shot though. I don't think it's worth trying to break it for his needs though ;)
Offline Rufus
« Reply #4 on: November 05, 2013, 10:39:48 am »
The PIC16F685 has optional protection for program memory and EEPROM. If the thing bothers to record how many cups it has made you would think they must have provided some way to inspect that information.
5 pins is very typical of PIC ICSP program/debug connections, they probably line up with pins 1 to 5 of the programmer/debugger you linked.
Being able to read the EEPROM still leaves you with the problem of understanding what you read.
Offline garak
« Reply #5 on: November 05, 2013, 01:29:55 pm »
Very true. Still, being a coffee machine, I kinda doubt deciphering any information that it's got stashed away in there would be too difficult. I mean, how complex could its life possibly be? Cup count, runtime, error codes? That's about all I can think of.
Online nctnico
« Reply #6 on: November 05, 2013, 05:20:24 pm »
There can be all kinds of information like the 'recipy'. But maybe its just blank. If it would count the number of cups it made then there should some way to read it. Maybe you can resurrect the PCB and see if there is some way to communicate with it.
Offline dannyf
« Reply #7 on: November 05, 2013, 08:39:44 pm »
That's assuming that the chip actually writes such data into the eeprom.
Otherwise, reading the eeprom isn't difficult, assuming that no data protection is enabled: all you need is a programmer, like pickit2/3 - <$50 at the high-end.
« Reply #8 on: November 05, 2013, 09:14:23 pm »
I guess I will find out in few days. I ordered pickit3 from Digikey. Looks like 5 through hole pads in the top right corner of the board match the hookup described in pickit3 documentation. I hope that EEPROM is not locked up.
« Reply #9 on: November 05, 2013, 09:30:56 pm »
$1000 - pretty steap price for 256 bytes from coffee machine's EEPROM  :o
I've heard that discharging flash from recyclable film camera near the IC while trying to navigate JTAG state machine sometimes can reset the right flip flop and allow to read data from IC even if it is has protection fuse.
Has anyone on this forum ever tried and succeeded reading protected flash or EEPROM?
« Reply #10 on: November 07, 2013, 12:05:05 am »
Well, I got the EEPROM contents, but I was unable to read program memory - it all came out 0s. I was careful not to overwrite it, but I don't exclude the possibility that I reset it by powering up device incorrectly or something like that, another explanation is that program memory is indeed protected. I got no warnings or errors while trying to read it.
    Address      00   02   04   06   08   0A   0C   0E                                                 ASCII
00             0A04 02A6 0096 3AF7 1A2C 60AA 0300 0900 .......: ,..`....
10             3000 4098 CA00 4C67 0000 0000 2900 0000 [email protected] .....)..
20             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
30             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
40             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
50             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
60             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
70             5753 3020 2E35 3530 4E20 4E41 FF4F FFFF SW 05.05  NANO...
80             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
90             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
A0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
B0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
C0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
D0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
E0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
F0             FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ........ ........
While looking at the board I found that 'N' pin which is connected to AC power input is not connected to GND (VSS) but to +5V VDD of net.
Why?  ???
This is not first time I see this but I am not sure why would someone design it this way?
Why?  ???
« Last Edit: November 07, 2013, 12:26:58 am by Alexei.Polkhanov »
Offline RoadRunner
« Reply #11 on: November 07, 2013, 12:13:43 pm »
PIC16F685 has separate protection setting bits for Data(EEPROM) memory and the Program flash.
as the read configuration bits shows only the Program memory protection is enabled. data (EEPROM) protection is not enabled.
that is why you get back all 0s when try to read Program Flash. PIC micro return 0s if the Flash memory is protected or return FFFFs if blank or erased.
user can enable any protection he wants although,
Quote from: datasheet
"It is recommended to code-protect the program memory when code-protecting data memory. This prevents anyone from programming zeroes over the existing code (which will execute as NOPs) to reach an added routine, programmed in unused program memory, which outputs the contents of data memory. Programming unused locations in program memory to ‘0’ will also help prevent data memory code protection from becoming breached."
Offline amyk
« Reply #12 on: November 07, 2013, 12:47:10 pm »
Looks like in this case code protection is on but data protection is off, thus you can read the EEPROM just fine. Now you'll just have to figure out what is stored in the EEPROM...
The board uses a nonisolated capacitive dropper supply (probably half-wave rectified), and since AC is AC it doesn't matter which lead is connected. The advantage of using N might be to reduce noise on the +5.
Offline mazurov
    • nerpa
« Reply #13 on: November 07, 2013, 04:41:50 pm »
You need to brew a cup of coffee and see what has changed in the EEPROM.
With sufficient thrust, pigs fly just fine - RFC1925
« Reply #14 on: November 08, 2013, 02:43:40 am »
I is using LNK304,  Off-Line Switcher IC, Datasheet:  http://www.mouser.com/ds/2/328/lnk302_304-306-179954.pdf I powered it up from my bench PSU by connecting +5V directly to +5V net on the board it never used more than 50mA.
I think I figured the counter, but it looks like it counts more like "cycles" not cups. It is a 16 bit number at 0A - 60AA (which later became 60AB. I understand 16 bit integers in PIC16F685 saved as little endian.
Offline abyrvalg
« Reply #15 on: November 08, 2013, 10:29:17 am »
Try flipping unused bits - maybe it will unlock some new features like 200MHz bandwidth double cups  :D
Offline amyk
« Reply #16 on: November 08, 2013, 11:59:18 am »
24746 cups is a lot of coffee...
Offline JTR
« Reply #17 on: November 08, 2013, 04:14:46 pm »
Maybe but how anything is saved to the data eeprom is entirely arbitrary. Endianess is at the whim of the firmware writer as there is nothing inherent with a 8-bit PIC's ISA that dictates data eeprom endianess. The value could just as easily be 938 power cycles or some such.
Offline trackman44
« Reply #18 on: November 09, 2013, 05:13:58 am »
The PIC16F685 has 256 bytes of EEPROM. Each address space is only 8 bits wide ( there is no 16 bit wide address space in the chip). Odds are that once it reaches a set value (x number of cups of coffee brewed) it will shut down. It was designed to fail. You just need to reset the number of cups brewed counter to zero. I would experiment and find out which byte it is that is incrementing ( the one that changed from AA to AB looks promising) you just have to brew another 86 cups to see what other byte will change (because it would go from FF to 00 and then the other byte will increment). Once you know that, reset both bytes to 00 and then the PIC will think it's brand new again.
Will
How 'bout them Maple Leafs?
Offline Teemo
  • Country: ee
« Reply #19 on: November 09, 2013, 01:01:48 pm »
Hello Alexei
Interesting teardown, thanks for sharing!
Offline Kjelt
« Reply #20 on: November 09, 2013, 03:42:26 pm »
Perhaps with fast consumables such as print cartridges this is the case but with expensive consumer goods such as these almost definetly not since these brands are looking for consumer binding they do a lot to give the consumer the best experience so they buy again in the future. It won,t help if all at a sudden all the machines in the world would start failing and the internet would be swamped with negative reviews  ;) there are less conspiracies out there then most peolple think.
Offline trackman44
« Reply #21 on: November 09, 2013, 08:11:35 pm »
True that. So i guess the other alternative is to change each byte up or down by one to see what happens. Also you need to determine if the machine really has failed. The PCB looks OK. Does anything else in the espresso maker look out of sorts? (Clogged tubes, short or open micro switches, micro switch arms bent too far, poor solder joints on wires, bent pinched burnt wires, burnt out LEDs, power supply voltages out of specs). Let us know Alexei.
Will
« Reply #22 on: November 09, 2013, 09:36:14 pm »
Will
Machine failed mechanically, it has a crack somewhere in piping and was leaking water. I was not trying to fix it I wanted to tear it down simply out of curiosity nothing more. There was no electrical failure in the machine of any kind and water leak did not short anything. It was definitely not designed for abuse it went trough and subsequently it was replaced by another machine of same model. It looks like it was made in Switzerland entirely - I found no "outsourced" parts in it at all. Plastic molding is so precise it is hard to see if it is multiple parts or one - I think that kind of plastic molding only comes from two places Germany and Japan.
« Last Edit: November 09, 2013, 09:38:05 pm by Alexei.Polkhanov »
Offline trackman44
« Reply #23 on: November 10, 2013, 12:11:14 am »
Oh. Ok then. So what are you planing to do with it? You cant read the program flash memory ( read protection is active). So your best bet is to analyze the data on the pins of the PIC so you have a basic understanding of what's going on ( which pins are outputs and what do they turn on,( motors, solenoids, LEDs, relays) which pins are inputs and are they assigned to the ADC?( water level, temperature sensing, key pad)). You could use a multimeter to measure the logic state, or a diode with a 1k resistor in series to probe the pins with, or a USB logic analyzer. Good luck learning the layout!
Will
Offline fluxcapacitor
« Reply #24 on: November 13, 2013, 01:03:43 am »
heres a great article entitled "Hacking the PIC 18F1320"
http://www.bunniestudios.com/blog/?page_id=40
