Author Topic: Reading the Code on a Microprocessor  (Read 3702 times)
Offline wayneeeTopic starter
« on: June 01, 2013, 09:05:12 pm »
Is it possible to read the code in a microprocessor once it has been placed on a circuit board?
Offline PeterG
Re: Reading the Code on a Microprocessor
« Reply #1 on: June 01, 2013, 09:14:44 pm »
I am not sure about Microprocessors but generally you can with Microcontrollers provided the chip is not code locked or otp.
Testing one two three...
Offline Dave
  • Country: si
  • I like to measure things.
« Reply #2 on: June 01, 2013, 10:31:32 pm »
Yes, if the code is not read protected, you should be able to extract a hex file from the microcontroller. Then use a decompiler to convert that hex file back into human-friendly assembly code.
<fellbuendel> it's arduino, you're not supposed to know anything about what you're doing
<fellbuendel> if you knew, you wouldn't be using it
Offline ninn
  • Country: at
« Reply #3 on: June 06, 2013, 02:37:16 pm »
I want to see that "human friendly" asm  >:D
Offline nuhamind2
  • Country: id
« Reply #4 on: June 06, 2013, 02:56:08 pm »
Aren't people in the past talk assembly.
Offline free_electron
    • SiliconValleyGarage
« Reply #5 on: June 06, 2013, 03:56:15 pm »
Sourcer always did a pretty good job ...
