Author Topic: Red Pitaya, HD images for getting the schematic  (Read 36368 times)
Offline londondockTopic starter
« on: October 28, 2014, 11:25:23 pm »
Hi All,
Album of Red Pitaya HD images
Here's some images of the Red Pitaya, a 50 MHz scope, waveform generator, and generally re-programmable measurement tool, based on the Zynq ARM(2Cores)+FPGA combo chip. I was an initial backer of their Kickstarter, and the board actually works excellent with the apps the dev team has developed for it. The fact that you can now cram a scope, function gen, spectrum analyzer, etc., onto a credit card sized board with modern chips is kind of amazing, in my opinion.
However, I'm disappointed at the refusal to release full electrical schematics for the supposedly "open source" project. My guess is they want to keep imitators from generating similar products, as they have now partnered with RS/Allied to sell the board for ~$500.
Feel free to trace your own schematics for the sections you want from these images. I'm going to be working on this sporadically to completely reverse engineer the complete schematic, because Dave has inspired me with his recent video on rev. engineering the Rigol 1054Z input cans...  :D
Obviously, this is a lot of work, so if you want to help with that (divide up the work, etc), I'd be up for that.
Offline Palmitoxico
  • Country: br
  • no
Re: Red Pitaya, HD images for getting the schematic
« Reply #1 on: October 29, 2014, 01:35:56 am »
I think that's impossible to reverse engineer it with only HD photos, this board surely has more than 2 layers and BGA stuff will make it even harder.
Isn't easier to project a whole new circuit than try to figure out all connections of this high density pcb?
Offline marshallh
    • retroactive
« Reply #2 on: October 29, 2014, 01:46:20 am »
You will need to depopulate the pcb, mill and sand down the layers and image them separately.
My guess puts it at 8 layers
Verilog tips
BGA soldering intro
« Reply #3 on: October 29, 2014, 03:18:52 am »
What do you mean by project a whole new circuit?
The board is indeed 8 layers, according to the transparent ladder diagram under the Ethernet jack.
I'm not planning on wrecking the board or sanding down the layers. Mainly I just plan overlaying via points, probing connections with a low voltage continuity tester, and then marking which points connect to each other.
Other things I've noticed so far:
-Not much in the way of input protection on SMA inputs/outputs. Only diode clamping in the amps/drivers really keeps it safe.
Lots of fast chips:
-AD8066, dual 145 MHz op amp on SMA-inputs
-LTC6200-10 165MHz, Rail-to-Rail op amps on SMA-outputs
-LTC6403, 200MHz, Low noise, low power fully differential input/output amp/driver for the main ADC
Offline marshallh
    • retroactive
« Reply #4 on: October 29, 2014, 03:38:06 am »
You are not going to be able to fully reverse the pcb like that unless you can remove some BGAs. Maybe just reverse the parts that are interesting to you and that are accessible. (Most of the stuff will be boring/boilerplate hookups that you don't care about)
Verilog tips
BGA soldering intro
« Reply #5 on: October 29, 2014, 03:47:56 am »
Yeah that's fair enough. Mostly I'm interested in the high speed input and output block diagrams.
Many of the BGA pin connections are listed in software header that's part of the Red Pitaya OS and base software headers. So there might be a little more to go on.
Offline tggzzz
« Reply #6 on: October 29, 2014, 09:11:23 am »
Thank you for you photos.
I concur with your belief that the principal benefit will be in understanding the i/o structures; complete reverse engineering is unnecessary.
I was particularly disappointed with the  implementation of the digital i/o on the E1/E2 connectors. IMNSHO they didn't have enough grounds, and they are not evenly distributed. In addition, the 3V3 i/o voltage precludes having differential input structures - and the replies to my questions didn't inspire confidence. FFI, see http://forum.redpitaya.com/viewtopic.php?f=9&t=32
I have not investigated "repurposing" the SATA connections for my ideas, since that would require deleting functional capability rather than adding to it.
Offline jboard146
« Reply #7 on: October 30, 2014, 03:03:07 am »
Get friendly with your dentist or vet. You need to get X-rays of the board.
Like others have posted it is 4+ layers.
Offline langwadt
« Reply #8 on: October 30, 2014, 08:35:50 pm »
runnning LVDS on Zynq with 3.3V IO is not a problem, just tell the tools you are running at 2.5V
if you turn on internal termination it'll be around 80R  instead of 100R but that's it
Offline tggzzz
« Reply #9 on: October 30, 2014, 11:50:19 pm »
Have you successfully done that on production equipment?
Why doesn't Xilinx indicate it is possible? Xilinx explicitly omit the possibility, thereby implying it is impermissable.
Offline langwadt
« Reply #10 on: October 31, 2014, 12:12:14 am »
I guess it may not be fully compliant LVDS that's why. I believe I saw it somewhere in a Xilinx
answer record
something like,
LVDS input always work, but you can't use termination, and you have to make sure the common mode
 with in range
LVDS OUTPUT/BIDIR, is not really supported because termination is always on, but it will probably work if you take into account the resulting termination value
if you set a port to CMOS25 and power it with 3.3V the drive levels will be higher which may or may not be a problem
Offline tggzzz
« Reply #11 on: October 31, 2014, 12:29:57 am »
answer record
something like,
 with in range
So, it might work. Or it might not work. Or it might work when the pattern is right. Or it might work for a while, until the overstressed i/o block subtly degrades.
When I'm pushing technology trying to get a 1or 2Gb/s signal into a device, I don't want to have to fight unknown and unalterable and uncircumventable behaviour.
Offline miguelvp
« Reply #12 on: October 31, 2014, 12:41:00 am »
The datasheet has 35 references about LVDS
http://www.xilinx.com/support/documentation/data_sheets/ds187-XC7Z010-XC7Z020-Data-Sheet.pdf
GPIOs usually support LVDS unless the datasheet stipulates that you should only use certain pins for certain functions (like JTAG for example)
To the OP, are you aware of this link:
http://wiki.redpitaya.com/index.php
GPIO16 module schematic:
https://www.dropbox.com/s/h4hmabxlf5xw7g4/Schematic_GPIO16_A_InformativeOnly.pdf
Also if you need to drive HDMI or longer drives where LVDS is not enough, then there is some paper somewhere on how to convert LVDS to TMDS. I did link it at a time a while ago. I'll do a search to see if I can find it.
Edit: Found it
http://m.eet.com/media/1135468/330072.pdf
« Last Edit: October 31, 2014, 12:43:15 am by miguelvp »
Offline langwadt
« Reply #13 on: October 31, 2014, 12:47:11 am »
answer record
something like,
 with in range
afair the minimum pulse width limits you to  ~350MHz on the Zynq
Input always works, you just have to use external termination if you don't use 2.5V
Powering a bank with a different voltage than you set it for will not damage anything,
but it the drive levels, fast/slow slew etc. might change so you IBIS simulations if you do
those will not be correct
Offline tggzzz
« Reply #14 on: October 31, 2014, 12:57:06 am »
answer record
something like,
 with in range
Are you referring to a clock signal, because I wasn't - consider SERDES. If you weren't, then I would be very interested in knowing the source of that information.
RedPitaya doesn't have any termination on the relevant lines, so it would be pattern sensitive. No point in adding off-board termination since the stub length is too long.
IBIS won't tell you anything about damage - and neither does Xilinx. I'm not going to risk basing a design on unsupported guesses - there's too much scope for very late unpleasant surprises.
Offline miguelvp
« Reply #15 on: October 31, 2014, 01:02:01 am »
I have no experience with xilinx other than I'm waiting for the Papilio Duo then I guess I'll dive into it but Altera has no trouble with LVDS signals,and the Red Pitaya does seem to have 8 available differential pairs in one of the connectors
If limited to ~350 MHz there is no reason you couldn't use multiple pairs.
Offline tggzzz
« Reply #16 on: October 31, 2014, 01:14:07 am »
Which LVDS i/o structures can be used with the 3.3V supply in the Red Pitaya?
Only one differential i/o structure can be used, TMDS - which is only for video signals.
Helpful.
I believe, without checking, that CN2 is the digital connector in question. It has 6 unconnected pins, 7 differential (14 single-ended) signals, but only 2 gnd pins and 2 3V3 pins at the end of the connector.  IMNSHO and without knowing the constraints on the board, it would have been preferable and possible to have 8 gnd pins distributed amongst the 14 signal lines. That would improve the signal integrity for high speed digital signals.
Edit: Found it
Interesting, but unhelpful since it requires 50ohm terminations at the receiver - which are not present on the Red Pitaya board (quite reasonably since they aren't required for most i/o standards).
Offline miguelvp
« Reply #17 on: October 31, 2014, 01:43:51 am »
So you can't put a 100 Ohm resistor across the pin pair?
Also they support TMDS according to the datasheet I linked before.
Edit: among other differential signaling that they support, it's in the datasheet.
Maybe this will help as well as in what SelectIO resources are available (link comes from the mentioned datasheet).
http://www.xilinx.com/support/documentation/user_guides/ug471_7Series_SelectIO.pdf
Edit, but what do I know, I only looked into this for less than 15 minutes total.
Some other relevant links
Implementation of a FPGA-based Interface to a High Speed Image Sensor
http://d-nb.info/1057871729/34
LVDS Display controller for microprocessors (using spartan though)
http://blog.tkjelectronics.dk/2012/10/lvds-display-controller-for-microprocessors/
Max10 (Altera) but I got an eval board for $30 so good to know it can handle it.
http://www.altera.com/literature/hb/max-10/ug_m10_lvds.pdf
Edit 2: Also I don't know how the board is done so I guess it's valid to assume the traces are not length matched.
« Last Edit: October 31, 2014, 02:00:25 am by miguelvp »
Offline tggzzz
« Reply #18 on: October 31, 2014, 02:11:04 am »
Please note the other points I have made about signal integrity w.r.t. terminations and insufficient poorly-distributed GND pins.
Yes, there is a reason I can't. My interest is in a signal that is inherently a 1Gb/s, preferably 2Gb/s single serial IO line. It will be parallelised inside the FPGA using SERDES I/O structure.
Offline tggzzz
« Reply #19 on: October 31, 2014, 02:19:16 am »
Not at the receiver, no. Somewhere away from the receiver, yes - but that's useless w.r.t. signal integrity.
Yes, I can tell, but thanks for making it explicit. I have looked at it for far longer.
I welcome specific examples of how to get a serial LVDS 1 or 2Gb/s signal into the Red Pitaya FPGA, given the Red Pitaya's implementation w.r.t. I/O voltage and lack of ground pins on the connector.
Offline miguelvp
« Reply #20 on: October 31, 2014, 02:38:42 am »
I guess you read both the datasheet and the Select IO app notes then.
Here is a 1050 Mb/s example (spartan 6)
http://www.xilinx.com/support/documentation/application_notes/xapp1064.pdf
Although that app note uses a clock of 150MHz so it requires the PLL and BUFPLL to run with a 7 multiplier to get to 1050MHz.
But since you are all convinced that you need ground pins on the connector for differential pair transmission then I don't know what else to say, Cat-6 is not affected by the lack of grounds around the signals.
Offline miguelvp
« Reply #21 on: October 31, 2014, 03:07:48 am »
Diff signals supported by the Zynq
Note the link about more information, that would be the other app note that I linked, and maybe you can even look for internal terminations while you are at it (meaning inside the FPGA)
Nope, the FPGA diff pins don't have enough grounds in between either for your signal integrity.
Offline alex.forencich
    • Alex Forencich
« Reply #22 on: October 31, 2014, 03:15:28 am »
I don't think that's entirely true.  There are solutions (ftjrev) for probing JTAG accessible devices.  As long as you can get access to the other end of the trace, you can figure out what pin it is connected to.  The DRAM chip will be connected to standard pins due to the onboard memory controller - consult the pinouts for the FPGA and it should be obvious.  Looks like the only BGA parts on the board are the FPGA and the DRAM, so it should be possible to back out most of a netlist without too much trouble.  Figuring out what all the passives are will be a more annoying problem, though.
Python-based instrument control: Python IVI, Python VXI-11, Python USBTMC
« Reply #23 on: October 31, 2014, 04:30:17 am »
Thanks Alex, that's basically what I was thinking. It's not like there are components hidden inside the PCB, so all parts that have solder exposed pins could be probed/traced back with a multimeter. Don't really need perfect values for all passives to get the general idea of what is going on with input/output blocks.
As an example, my first section was just to see how they have implemented the IN1 and IN2 input stages, with the jumpers for "low" and "high" voltage signals. Picture is attached.
After the AD8066 op amp, there is a bunch of surface mount inductors before the LTC6403 driver. I've not done much RF design work myself, so I find it interesting how they basically get good (ie. flat or nearly so) response up to the claimed bandwidth of 50 MHz with lumped element SMD chips placed on these tiny traces. I just figured all RF boards were controlled impedance microstrips, etc., but I've only been doing electronics as a hobby for about 3 years now. I guess you just need to know your amps/passive components SPICE models/parameters and model away?
    • Alex Forencich
« Reply #24 on: October 31, 2014, 05:20:47 am »
50 MHz is not so bad.  The wavelength in the air at 50 MHz is 6 meters, so basically anything that you can stick in a box that sits on your desk is going to be lumped element, much less stuff on one board.  5 GHz, on the other hand, has a wavelength of 6 cm, so distributed effects are much more pronounced.  It gets really fun as you start getting up there - for example, 50 GHz has a wavelength of 6 mm, so you would get a significant phase shift going through an 0402 SMD component!
