Probably enough cable to be worth adding some source termination resistors, about 50-100 ohms. More if you don't need the speed.
Use more pins, and ground every other wire (50 mil pitch ribbon, dual row header, one row grounded -- nice and simple). This gives a transmission line impedance of about 100 ohms, and reasonably low crosstalk.
Mind that SPI will be susceptible to more than modest EMI (i.e., >3V -- enough to violate logic thresholds, despite the extra grounds). You can help that a little by adding filtering (ferrite beads and extra capacitance), but this directly affects maximum baud (just as the extra resistance does). If you only need a few hundred kHz, it can help a lot.
