Author Topic: Reset for programming 328p  (Read 2081 times)
Offline vini_iTopic starter
« on: January 13, 2015, 03:15:50 pm »
i'm designing a board with a atmega328p (uno) and a ftdi chip ft230x. originally i was just going to debug with the ftdi chip but i figured i might as well set the board up for programming with a boot loader. normally we program with a usb tiny isp.
what would be the appropriate way to hook up the ftdi chip to the 328p to generate a reset before programming?
Offline Michal_S
Re: Reset for programming 328p
« Reply #1 on: January 13, 2015, 04:16:37 pm »
For example, Arduino uses DTR line connected through a capacitor to the AVR reset pin. You can look up the schematic (Arduino Nano) http://arduino.cc/en/uploads/Main/ArduinoNano30Schematic.pdf.
