I've seen a number of people asking about this display. No specs available. It has a nice 40x50mm LCD and controls. From inside, it looks like a generic CPU is driving the LCD panel and brokering button presses back to another CPU.
With the Cannon board and panel connected, the board starts up and generally works (vid link below). The button presses and LED signals, I got, they are srial Tx/Rx at 19200 baud.
https://youtu.be/7dj8Rzvtl2AThe display driving signals, they look different. SPI? sdio? Kind of looks like SDIO but there is no clock signal. Also, there is this wierd 20ns blip. Almost looks like scan lines but still not quite. Any ideas?
The controller is marked mb87m8260
Overview:
Screen Shot 2022-04-23 at 4.17.31 PM.png (52.32 kB. 991x381 - viewed 192 times.)
First burst:
Screen Shot 2022-04-23 at 4.18.23 PM.png (71.13 kB. 1010x370 - viewed 114 times.)
Detailed lines?:
Screen Shot 2022-04-23 at 4.18.40 PM.png (56.99 kB. 1016x371 - viewed 128 times.)
That blue trace, is either 20 or 40ns. It always leads or lags with one edge matching either the yellow signal or the green signal exactly. Some kind of framing signal?
The yellow trace looks like four bytes then some kind of framing high whilst the green line sends a response byte? It goes on like that but that blue trace is all over the place. Later on, the pattern changes.
Think it just may be UART in two directions at an odd bit rate (53000 bits/s).
Hmm, so, for the boot sequence in the video, there are about 1248 bytes of data transmitted from control board to the panel processor. That certainly isn't enough for raw image data. There appears to be a higher level protocol at play here. There are fonts, shading, a dialog box with a paragraph of text. There is 1Meg DRAM on the control panel. There is no eeprom so if there is pre-loaded forms/fonts etc. then they are in a OTP part of that processor. Not looking good. If it is OTP with pre-set text etc. it is toast. If it is something like OpenGL, then it may be usable. Real shame as the buttons are all streightforward to decode. The action wheel works quite nicely too.
