Author Topic: RP2040: how to use FreeRTOS with TinyUSB?  (Read 7617 times)
Offline mblinovTopic starter
« on: March 12, 2023, 12:01:00 pm »
Hi all,
Quite basic question but the answer eludes me. How to sanely use FreeRTOS with the TinyUSB that is shipped with pico-sdk?
So pico-sdk contains TinyUSB as part of its distribution. If you clone pico-sdk, you will find it under pico-sdk\lib\tinyusb.
However, here's the catch: If we look in pico-sdk\lib\tinyusb\hw\bsp\rp2040\family.cmake (note it is a git submodule), which is the file that specifies compilation options for the RP2040 MCU, we find that CFG_TUSB_OS is hardcoded to OPT_OS_PICO:
        target_compile_definitions(tinyusb_common_base INTERFACE
                        CFG_TUSB_MCU=OPT_MCU_RP2040
                        CFG_TUSB_OS=OPT_OS_PICO
                        #CFG_TUSB_DEBUG=${TINYUSB_DEBUG_LEVEL}
Which is fine for all normal purposes. However, I'd like to use FreeRTOS in my app, and consequently (atleast, it would seem to me) that I need to set this to be OPT_OS_FREERTOS in place of OPT_OS_PICO. Unfortunately, it does not seem to be a configurable option (for the time being I can ofcourse change it directly in the sdk source code.)
Now what I *could* do instead is supply my own tusb_config.h file, and override CFG_TUSB_OS in there instead. I can confirm that the compiler picks up my header file, because I see lots of warnings like
warning: "CFG_TUSB_OS" redefined
   46 | #define CFG_TUSB_OS OPT_OS_FREERTOS
Which is "good" since it implies it's picking up my option (but also not good because it's clearly not the right way to go about it!)
However the build fails, I think because it picks it up my header file "too late" so to speak. I get unknown type name and implicit declaration of function errors, which suggests that some object files are being compiled with OPT_OS_PICO while others with OPT_OS_FREERTOS, and consequently some C files are trying to use symbols which haven't been compiled.
I want to know, what is the "correct" way of doing what I'm trying to do? Obviously its trivial to modify the SDK directly, but I really don't want to drag a slightly-custom pico-sdk together with my project.
I seem to have some kind of faint memory of seeing FreeRTOS <-> "Pico OS" interop, atleast as far as the various synchronization primitives go, which would mean that what I'm trying to do is completely needless. But I can't remember where I got this impression from.
« Last Edit: March 12, 2023, 12:06:28 pm by mblinov »
Re: RP2040: how to use FreeRTOS with TinyUSB?
« Reply #1 on: March 12, 2023, 12:42:41 pm »
Ok, so actually its not quite as simple as just changing the pico-sdk\lib\tinyusb\hw\bsp\rp2040\family.cmake file. I still get the same unknown type name and implicit declaration of function errors, but they are *not* due to some hand-wavy inclusion error.
I neglected to post these errors in the OP, here they are below:
[4/5] Building C object [...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c.obj
FAILED: [...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c.obj
[...trimmed content...]
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c:38:8: error: unknown type name 'critical_section_t'
   38 | static critical_section_t one_shot_timer_crit_sec;
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c: In function 'timer_task':
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c:49:9: warning: implicit declaration of function 'critical_section_is_initialized' [-Wimplicit-function-declaration]
   49 |     if (critical_section_is_initialized(&one_shot_timer_crit_sec)) {
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c:50:9: warning: implicit declaration of function 'critical_section_enter_blocking' [-Wimplicit-function-declaration]
   50 |         critical_section_enter_blocking(&one_shot_timer_crit_sec);
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c:52:9: warning: implicit declaration of function 'critical_section_exit' [-Wimplicit-function-declaration]
   52 |         critical_section_exit(&one_shot_timer_crit_sec);
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c: In function 'stdio_usb_init':
[...long path...]/pico-sdk/src/rp2_common/pico_stdio_usb/stdio_usb.c:213:9: warning: implicit declaration of function 'critical_section_init_with_lock_num' [-Wimplicit-function-declaration]
  213 |         critical_section_init_with_lock_num(&one_shot_timer_crit_sec, next_striped_spin_lock_num());
ninja: build stopped: subcommand failed.
Now, if I undo all my changes (that is, let CFG_TUSB_OS=OPT_OS_PICO) and look at who includes who, the following comes up:
If we select CFG_TUSB_OS=OPT_OS_PICO (the default), then the following inclusion chain occurs:
pico-sdk\src\rp2_common\pico_stdio_usb\stdio_usb.c:
- pico-sdk\lib\tinyusb\src\tusb.h
  - pico-sdk\lib\tinyusb\src\osal\osal.h
    (here it is decided who to include based on OS)
    - pico-sdk\lib\tinyusb\src\osal\osal_pico.h
      - pico-sdk\src\common\pico_sync\include\pico\critical_section.h
        (Here, `struct critical_section` is defined (among others.))
  - pico-sdk\src\rp2_common\pico_stdio_usb\include\pico\stdio_usb.h
However, if we select CFG_TUSB_OS=OPT_OS_FREERTOS, then the following inclusion chain occurs:
    - pico-sdk\lib\tinyusb\src\osal\osal_freertos.h
We never did include critical_section.h, and as a consequence the build fails, since the stdio_usb.c file is implemented using those primitives.
I'm inclined to suggest that this is an oversight: The printing logic (stdio_usb.c) is a *consumer* of the TinyUSB library, not an integral part of it. By that logic, it should not depend *at all* on whether TinyUSB itself is targetting FreeRTOS, or using pico-sdk primitives, or whatever.
Infact the fix is trivial: We simply need to include critical_section.h directly from stdio_usb.c:
diff --git a/src/rp2_common/pico_stdio_usb/stdio_usb.c b/src/rp2_common/pico_stdio_usb/stdio_usb.c
index 32f1f33..c91af99 100644
--- a/src/rp2_common/pico_stdio_usb/stdio_usb.c
+++ b/src/rp2_common/pico_stdio_usb/stdio_usb.c
@@ -16,6 +16,7 @@
 #include "pico/time.h"
 #include "pico/stdio/driver.h"
 #include "pico/mutex.h"
+#include "pico/critical_section.h"
 #include "hardware/irq.h"
 #include "device/usbd_pvt.h" // for usbd_defer_func
Offline dobsonr741
« Reply #2 on: March 12, 2023, 03:16:17 pm »
Perhaps worthy of a pull request?
« Reply #3 on: March 12, 2023, 06:08:27 pm »
To be honest I'm still not sure if what I'm trying to do isn't completely insane.
I just came across the following text in the RP2040 SDK manual:
In any case: Continuing from my previous post... Unfortunately I don't remember the details anymore, I think what bit me was that if you want to call tud_task and board_init, you need to add to your CMake project the TinyUSB link targets, e.g.:
target_link_libraries(${CMAKE_PROJECT_NAME} pico_stdlib tinyusb_device tinyusb_board FreeRTOS-Kernel FreeRTOS-Kernel-Heap3 pico_unique_id)
And as explained in the manual above, linking against tinyusb_device and tinyusb_board actually has a consequence on codegen: There is code in the pico-sdk library that detects you're explicitly linking against TinyUSB, and will turn off the stdio-USB printing logic (or some of it.)
Basically there is really quite intricate interplay between printf, TinyUSB, and the larger pico-sdk library. Consequently if you want to do anything that isn't absolutely out-the-box standard printf-over-USB, it seems best to create a completely custom TinyUSB endpoint from scratch, and use that.
You're not completely left out in the cold though, as the stdio subsystem provides a function called stdio_set_driver_enabled, which lets you provide a stdio_driver_t structure.
I then copied the files pico-sdk\src\rp2_common\pico_stdio_usb\stdio_usb.c and pico-sdk\src\rp2_common\pico_stdio_usb\stdio_usb_descriptors.c, modified slightly to work standalone, and had essentially a CDC endpoint that behaved exactly like printf, only I can now set the manufacturer string, manage it from FreeRTOS, etc.
« Last Edit: March 12, 2023, 06:15:23 pm by mblinov »
Offline rapzak
« Reply #4 on: March 24, 2023, 07:47:46 pm »
Have you found any better/easy solution to this problem?
I am now in same boart...
/Kasper
« Reply #5 on: March 25, 2023, 04:41:15 pm »
Unfortunately not. I did open a discussion in the TinyUSB github repo, so there is some upstream visibility into this problem.
Offline rapzak
« Reply #6 on: March 26, 2023, 09:37:36 pm »
Thanks for the update.
I think the Pico SDK could have and option for this input in the cmake file like these:
# create map/bin/hex file etc.
pico_add_extra_outputs(${NAME})
# enable usb output, disable uart output
pico_enable_stdio_usb(${NAME} 0)
pico_enable_stdio_uart(${NAME} 0)
/Kasper
Offline rapzak
Offline westfw
« Reply #8 on: March 27, 2023, 05:30:26 am »
I would have thought that "tinyUSB" was a sort of "full stack" USB implementation designed for systems that don't use an RTOS, so that if you want to use FreeRTOS on an RP2040, you'd have to find a FreeRTOS USB stack.  Probably that would rely on lower-level USB hardware drivers, and use the FreeRTOS scheduling primitives for the more complicated levels, instead of whatever mechanisms TinyUB uses to implement multiple IO streams in a taskless environment.     (perhaps not.  It seems that FreeRTOS is lower level and doesn't have a standardized USB abstraction.)
Offline SiliconWizard
« Reply #9 on: March 27, 2023, 06:31:15 pm »
TinyUSB supports no OS, FreeRTOS, RT-Thread and Mynewt. The best bet is not to think, but to look at the project. ;D https://github.com/hathach/tinyusb
The problem here is that TinyUSB's FreeRTOS support for the RP2040 is not quite there yet. It's not a limitation of TinyUSB, just something that is not fully ready yet.
