I made a design with a rpi CM4 module connected to my own PCB. As far as i know all the connections to the CM4 module are correct. Sadly enough the CM4 doesn't power/boot up. I can measure 5V at some caps on the CM4 module. The other caps show no voltage at all. I don't understand why the CM4 module doesn't generate the 3,3V rail. The troubleshooting guide on the RPI website doesn't help me also. I've checked the Global_EN signal and this is high, the guide says if 5v is available the other rails should power up. So i don't see any reason why the CM4 module doesn't generate it's own voltage rails. Any advice on this?
