Author Topic: SAM4E flashing first program  (Read 1504 times)
Offline hsn93Topic starter
  • Country: bh
« on: December 05, 2018, 02:45:38 pm »
hello,
i've designed board for SAM4E16E.
a very bad move i did is that i did not connect any pin in the board to led (flashing leds is really helpful for debug) or didnt put jtag connector.
anyway, i only have Erase option on the board.
and its connected to USB.
so i've connected it to the PC and i can see (COM4 as "Bossa Program Port")
now im using Bossac which supports SAM4E. to upload simple program:
after flashing the firmware, and reset, i still see the "COM4" which means the bootloader is still there? shouldnt it exit to my software until i erase the chip?  |O
what i can think of, is that SAM-BA checks for the program and cant find it in the memory, but i didnt play with the flash.ld file
flash.ld: https://pastebin.com/raw/YRZuefCa
the code has infinite loop also:
#include <asf.h>
int main (void)
/* Insert system clock initialization code here (sysclk_init()). */
board_init();
/* Insert application code here, after the board has been initialized. */
while(1)
« Last Edit: December 06, 2018, 05:43:32 am by hsn93 »
  • Country: bh
Re: SAM4E flashing first program
« Reply #1 on: December 06, 2018, 05:41:55 am »
the problem solved
there is boot from flash that you can set in SAM-BA i guess (somthing like fuses)..
boot to ROM bootloader from ASF code: (add flash_efc service)
flash_clear_gpnvm(1);
NVIC_SystemReset();
« Last Edit: December 06, 2018, 08:14:22 am by hsn93 »
