Author Topic: SDI-12  (Read 1999 times)
Offline YU7CTopic starter
  • Country: cs
SDI-12
« on: August 30, 2017, 03:43:58 pm »
I have to develop SDI-12 to SPI bridge, and thought it will fine if I find SDI-12 protocol analyzer.
So, is there on the market cheap simple a logic analyzer who can decode SPI-12 protocol commands?
Vojislav
Offline Rerouter
Re: SDI-12
« Reply #1 on: August 31, 2017, 09:45:03 am »
SDI-12 looks to be a high level interface running on a 1200 baud, bidirectional serial link, (Automotive K-line / Key Word Protocol, sounds almost like an exact match)
For decoding this before i have just used a 8 bit logic analyser, with some resistors to define the correct high / low thresholds (K-line logic 0 is 25-35% of VCC)
You would then decode it as Async Serial, and all the data would be there, You would then just have to review which side is requesting to nut out which side is talking at a given time.
The following users thanked this post: YU7C
