Hello guys,
I know I said I'm not too fond of buying stuff from China, but I did it anyways...
I bought an Altera MAX II EPM240T100C5N with a USB Blaster. I'm still thinking about buying some from farnell.
It came in today !
I've downloaded the latest version (12.1) of Quartus II Web Edition from Altera (it took like 4 to 5 hours to download and install
Then I made a quick and easy clock divider (20MHz to 2Hz). Took me a while to get it all set correctly but I managed to get it all compiled, assign the correct pins, etc, and it works !
I got two issues with hardware and software.
I couldn't get the pins assigned, but I just did it wrong
The other issue is when I plugged the USB cable in the USB Blaster and PC, nothing happened. The power LED turned on but nothing popped up on windows (new device detected, installing driver etc).
Cheap ass USB cable was damaged ! I changed the cable and it works very well.
Anyways, everything works nice.
Thanks again for everyone's help.
