Author Topic: sim900A embedded at applications notes  (Read 2236 times)
Offline dizgahTopic starter
« on: December 07, 2014, 01:41:51 pm »
hi dear friends
i am trying to design a wireless data logger device based on a simcom sim900a gsm/gprs modem.
& eliminating external mcu is very pleasure to me ,then sim900's mcu will do process.
as you know simcom used arm926ej arm 9 mcu on sim900 which is absolutely enough for many embedded applications.
simcom publish a pdf as "sim900 embedded at applications notes" for reference that i have a bit confused of undrestanding its mind.
is there any body here do this past or has any experiences in this?
i think we only write tasks for its real time os ?is it true?
or for example with at+command i can connect with http to a server on internet & based on get/post requests send & receives datas via sim900's usart port ? but i dont know how can send/received this datas when im not using external mcu(transieve from core mcu to my application)
can any one clear me or give me some simple examples?
best regards
Happiness can be found, even in the darkest of times, if one only remembers to turn on the light.
Albus Dumbledore
