Author Topic: Simple PIC12F509 code does not work  (Read 2747 times)
Offline ocsetTopic starter
« on: September 08, 2017, 11:08:31 am »
Hello,
Please do you know why my C code (XC8) for PIC12F509 doesnt work?
All its supposed to do is read a square wave voltage input on GP5, and then change  GP4 from high to low every second low-going of GP5.
However, GP4 is always just staying low. Do you kow why?
it builds sucessfully but doesnt work.
 * File:   jitter.c
 * Author:
 * Created on 8 sept 2017, 23:55
//this code jitters
//This uses PIC12F509
//MPLAB X IDE
//XC8 C compiler (free)
#define  _XTAL_FREQ 4000000
#include <xc.h>
#include <stdint.h>
#pragma config OSC = IntRC      // Oscillator Selection bits (external RC oscillator)
#pragma config WDT = OFF        // Watchdog Timer Enable bit (WDT disabled)
#pragma config CP = OFF         // Code Protection bit (Code protection off)
#pragma config MCLRE = OFF       // GP3/MCLR Pin Function Select bit (GP3/MCLR pin function is MCLR)
//I have not set the MCLR pin as an input because it will be noise susceptible.
//Therefore i set MCLR up as reset, but i will never use it as reset..but will
//simply tie the pin top Vdd on the PCB.
//Declare functions which set up the microcontroller
//void    disable_interrupts(void);   //How do this?
//void    disable_pullups(void);      //How do this?
//    TRIS = 0x18;
//Declare variables
    uint8_t   count;
void main(void) {
    GP0 = 0;
    GP1 = 0;
    GP2 = 0;
    GP4 = 0;
    GP5 = 0;
    OPTION = 0xD7;
    TRISGPIO = 0x20;
    GP4 = 0;
    //5 second delay
    for (count=1;count<=50;count++)   {
    __delay_ms(100);
    while(GP5 == 0) ;
    while(GP5 == 1) ;
    //STATUS LOW FIRST
    //When it gets to this point, the STATUS input has just gone low
    __delay_us(500);
    GP4 = 0;              //FET OFF
    while(1){
    while(GP5 == 0) ;   //See out the rest of low STATUS
    while(GP5 == 1) ;   //See out the high STATUS
    while(GP5 == 0) ;   //See out the low STATUS
    //STATUS LOW SECOND
    __delay_us(500);
    GP4 = 1;              //FET ON
    __delay_us(500);
    GP4 = 0;
    while(1){;}
    return;
« Last Edit: September 08, 2017, 10:01:14 pm by treez »
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
Re: Simple PIC12F509 code does not work
« Reply #1 on: September 08, 2017, 02:34:22 pm »
You mean GP4 is staying low?
Seems to work in the simulator, so I suspect a hardware problem. Can you post the schematic and/or a photo of the setup?
The following users thanked this post: ocset
Offline woody
« Reply #2 on: September 08, 2017, 04:02:25 pm »
GP5 is the input, right? So if that stays low, what is it connected to?
Assuming you have real hardware tie an LED (with a series resistor) to GP0 and use that LED as a signal to find out where your program actually comes (I am not familiar with the XC8 compiler so might have the syntax wrong):
gp0=1;
while(1);
This always helps me to find out where my program takes an unexpected left turn.
And I presume you have executed the mandatory 'blink-a-led' exercise with your hardware to make sure the controller actually runs (has power on the right pins, has its oscillator and fuses configured correctly).
Paul
« Reply #3 on: September 08, 2017, 08:13:59 pm »
I may have missed the obvious...
All its supposed to do is read a square wave voltage input on pin 5,
Pin 5 is GP2, not GP5. Either input the square wave on pin 2 (GP5) or change the code to use GP2 as the input.
« Reply #4 on: September 08, 2017, 10:02:17 pm »
Sorry i do apologise, GP5 is the input and GP4 is the output. My Bad. I am kicking myself now.
Thanks Ill try the LED thing etc...the code is so simple that i was hoping to just write it once and done.
« Last Edit: September 08, 2017, 10:04:24 pm by treez »
Offline rstofer
« Reply #5 on: September 09, 2017, 01:07:29 am »
That NEVER happens, I don't care how simple the code may be!
The following users thanked this post: JPortici, BrianHG, ocset
