Author Topic: ST10F273 bootstrap mode  (Read 2874 times)
Offline EEVadityaTopic starter
« on: January 29, 2015, 12:49:27 pm »
Hello,
Can anyone guide me how to program ST10F273 in Bootstrap mode.
Kindly provide the procedure & supporting technical documents.(Connection Diagram)
Offline Skimask
Re: ST10F273 bootstrap mode
« Reply #1 on: January 29, 2015, 01:08:58 pm »
RTFDS
I didn't take it apart.
I turned it on.
The only stupid question is, well, most of them...
Save a fuse...Blow an electrician.
« Reply #2 on: January 31, 2015, 04:41:30 pm »
Datasheet doesn't have that information
Offline Skimask
« Reply #3 on: February 01, 2015, 04:58:29 pm »
Really...
Then I guess nobody can do what you need...
I turned it on.
Offline miguelvp
« Reply #4 on: February 02, 2015, 04:25:45 am »
http://www.st.com/web/en/resource/technical/document/datasheet/CD00157816.pdf
Search for bootstrap (33 references)
Chapter 6 (page 49) has most of it but other references but the memory and flash memory sections do have more info about the bootstrap loader as well as the system reset section.
