Author Topic: STC 12c5a60 with TL866 (II) programer  (Read 3684 times)
Offline alanbTopic starter
« on: December 23, 2019, 11:11:26 am »
I purchased a TL866(II) programmer specifically to read and reprogram an STC12c5a60s2 microcontroller discovering later that it is not on the list of supported chips.
Are there any known workarounds for this? for example:
a)selecting a chip from another supplier with equivalent programming characteristics and pin outs.
b)Third party software that supports the  STC12c5a60s2
c) A way to add new devices to the existing TL866 software?
Thanks in advance
Alan
Offline wraper
  • Country: lv
Re: STC 12c5a60 with TL866 (II) programer
« Reply #1 on: December 23, 2019, 11:18:46 am »
You don't need any programmer. It can be programmed in circuit via UART.
« Reply #2 on: December 23, 2019, 11:24:26 am »
Are you able to point me in the right direction for details of doing this?
Offline wraper
  • Country: lv
« Reply #3 on: December 23, 2019, 11:59:05 am »
Open datasheet, there is schematic. Basically you can buy cheap USB-UART adapter and connect it directly to MCU. Or connect to COM port through voltage level shifter.
« Reply #4 on: December 23, 2019, 12:14:36 pm »
Thanks for help. Unfortunately I don't think I will be able to get an adaptor until after the holidays.
Do I need any software to  upload / download the program to the device from a windows PC?
« Last Edit: December 23, 2019, 12:16:07 pm by alanb »
Offline wraper
  • Country: lv
« Reply #5 on: December 23, 2019, 12:22:04 pm »
The following users thanked this post: alanb
« Reply #6 on: December 23, 2019, 12:33:13 pm »
Thank you very much for all of your help with this. Sorry for asking such basic questions which in retrospect I should have researched my self.
Alan
Offline WattsThat
« Reply #7 on: December 25, 2019, 09:16:23 pm »
For non-Windows users, there is the STCGAL tool written in python available on github. https://github.com/grigorig/stcgal
Note that you cannot copy or duplicate STC parts, you must have the source or object files to program a device.
