Author Topic: STM 32F4xx - limitations on a DMA controller configuring another DMA controller  (Read 740 times)
Offline peter-hTopic starter
There are some bus limitations, mentioned here in a recent thread. But in general, is this supposed to work?
I have a feeling one could do quite clever stuff with that.
Offline wek
  • Country: sk
Yes, and you can use only DMA2 to DMA into DMA.
Yes, why not.
Hardly so.
Among other things to start a transfer you need to write at least to two discontinuous registers (clear the TC flag and set the enable bit), and for anything even marginally useful also to the memory pointer register, and maybe also the count (NDTR) register. That is, you'd need 2-4 other DMA streams to serve this one. Probably doable, but doesn't sound to be useful.
Newer STM32 ('H5 for example) have a much more sophisticated DMA.
JW
