Author Topic: STM32 Eclipse Etc - Windows 10 compatible ?  (Read 1612 times)
Offline picandmixTopic starter
« on: June 09, 2016, 08:44:12 pm »
Just been looking at the recent thread https://www.eevblog.com/forum/microcontrollers/alternative-to-coocox-for-stm32-development/msg943412/#msg943412 and the comments from Sal Ammoniac and Quarlo Klobrigney about installing Eclipse and its tools etc.
Wanted to know if they all work ok on both my current Windows 8.1 or perhaps the soon to be  Windows 10 upgrade?
thanks
Offline uncle_bob
Re: STM32 Eclipse Etc - Windows 10 compatible ?
« Reply #1 on: June 09, 2016, 08:59:03 pm »
Hi
Don't know about the specifics of the STM32 toolchain. All of the other Eclipse based tool chains I have tried work fine on Windows 10 in the 64 bit flavor. I would be amazed if the same did not apply to the ST stuff. The only exception might be some chunk of proprietary this or that they dragged in to make it all work. Normally you don't have to do that with most of the ARM stuff.
What you do still run into on any version of OS are programming gizmos that go out of sync with the latest drivers. It's pervasive enough that you simply accept that any dongle can go out of date at any time. When they do, you either freeze things on the old drivers (and likely accept other problems) or you shell out for the new dongle. Whenever this sort of thing happens, there is always a lot of finger pointing. It's more common in the FPGA world than in MCU's.
Bob
Offline Sal Ammoniac
« Reply #2 on: June 09, 2016, 11:37:46 pm »
I use Eclipse (Mars) on Windows 8.0, 8.1, and 10 and it works fine on all. Both 32-bit and 64-bit flavors.
Edit: Works fine on Windows 7 too.
Complexity is the number-one enemy of high-quality code.
« Reply #3 on: June 09, 2016, 11:39:55 pm »
I use a Segger J-Link and Segger is very good about updating drivers to track the OS versions.
Offline uncle_bob
« Reply #4 on: June 09, 2016, 11:47:48 pm »
Hi
The J-Link works fine on Windows 10.
Bob
